• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
There is no such script that can call multiple regular expressions
Enthusiast ,
Feb 25, 2017 Feb 25, 2017
That is, I hope to perform multiple regularities at the same time
I can increase the need to call the regular
Thank you very much~~~
TOPICS
Scripting
Views
974
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Feb 26, 2017 Feb 26, 2017
Be more explicit!
Votes
Translate
Translate
Report
Report
Guru ,
The FindChangeByList script is preinstalled in InDesign. It works with the current document.
If you need to run it against multiple files, here I wrote the version which can be used in the batch processor.
— Kas
Votes
Translate
Translate
Report
Report
Enthusiast ,
Feb 27, 2017 Feb 27, 2017
Hi~Kasyan Servetsky
Thank you
Maybe I did not express it clearly.
I mean: a script calls a number of regular, and just to be easy to modify, and to see regular.
Also, the script (BatchFindChangeByList.jsx) is wrong?
Votes
Translate
Translate
Report
Report
Guru ,
I must have misunderstood your question. Did you mean 'regular expressions' (GREP) or something else?
If the former, the scripts I mentioned allow you to run a number of find-change regular expressions in one go, and you can easily see and edit them in the FindChangeList.txt file.
BatchFindChangeByList.jsx is intended for the batch processor only. It can't be used as a stand alone script as it is. (Read the description)
— Kas
Votes
Translate
Translate
Report
Report
Enthusiast ,
Mar 08, 2017 Mar 08, 2017
I mean just like this:
Run a script, A panel appears.It calls multiple regular expressions while running.
In this panel you can set a number of regular (like Figure A, Figure B ... Figure C ...), an option can be set to 1 2 3 4 and 5 several options.
I Can be free to increase or decrease the regular expression in the panel.
Votes
Translate
Translate
Report
Report
Guru ,
Mar 09, 2017 Mar 09, 2017
LATEST
Check out the Multi-find/change script.
Votes
Translate
Translate
Report
Report
