So I'm using the camera tracker to find the points of my image I want to track and create 3D space.
The camera wasn't that shaky and I'm getting like .19 on the frame errors. The second I add ANYTHING it causes the BB-8 3d model to go nuts. It makes the model go to the bottom of the screen where it starts to jittery, then fly off the screen.
Text and solids work great and I'm just trying to get the model to go from the garage up to the camera which shouldn't be hard, but why does adding anything cause it to go nuts? Images have the same problem of being jittery like trying to do track motion with a bunch of grain in the video, but this is pretty clear.
Help?
You probably will have to scale/ rotatte/ move the scene. Since it can't be calibrated, the AE 3D Tracker solution is arbitrary and from producing super tiny values to ones big as a galaxy anthinsg is possible. Using a plug-in like E3D that has its own problems with clipping and scale clearly doesn't make things easier. Start by checking your actual values. It could simply be that your "floor" is somewhere up in the sky or the camera uses a large zoom factor. Then find a script that scales the values.
Mylenium
First, did you set an origin and ground plane? It's important to do that. Second, since placing a text and solids work great and we have no idea what kind of footage or what effect you are using to create the 3D model I think that's where your problem is. It's always easier to get help when you give us a full screenshot with the modified properties (press the u key twice) of the layer giving you problems revealed. Cropped screenshots are seldom very helpful in diagnosing the problem. Just print screen and paste (Shift + Ctrl/Cmnd + 3 and drag from the desktop on a Mac).
I think the problem is how you are adding the 3D model of BB-8. Here's how I would approach the problem.
That should do it. If you are using Element 3D for your model you'll have to go through a slightly different workflow but the idea is the same. Get your solid to move correctly from point to point in the scene, Any other workflow an animated 3D model and AE's Camera Tracker is going to be problematic and probably won't work at all.
If you are using 2D footage of BB-8 then Camera Tracker is the wrong tool. You'll want to stabilize the footage so there is no camera movement using AE's tracker and choose Stabilize Motion. All camera movement is now stopped. If the camera moves into the scene or has rotation you'll need to also track scale and rotation. When you have the camera motion removed you add the 2D footage and animate the scale and position as needed. Then you can add the motion back into the shot by adding a null to the timeline, renaming the footage "stabilized" and then adding this animation preset to the Null. Dropbox - destabilize Rotation Scale.ffx
This will add the following expressions to the null:
position:
thisComp.layer("stabilized").transform.anchorPoint
scale:
x = value[0];
y = value[1];
tx = thisComp.layer("stabilized").transform.scale[0];
ty = thisComp.layer("stabilized").transform.scale[1];
nx = x/tx*x;
ny = y/ty*y;
[nx, ny]
rotation:
- thisComp.layer("stabilized").rotation
Now move the CTI to the first frame and make Null 1 the parent of the original footage and the footage of BB-8. This will put the motion back in the stabilized footage and add the camera motion to the footage of BB8
I hope this helps. It would have been easier to post a potential solution to your problem if you had given us a more detailed explanation of your workflow.
