6 Replies Latest reply on Feb 27, 2017 3:56 AM by dj_paige
    LR Freezes When Moving Folders
    205EdMLewis
      Hello! I have pictures in two directories after moving from Elements to Lightroom. I can't drag and drop folders from the "Ed's Pics" directory (45K) to the "Pictures" directory (15K) in Lr without my system freezing. Even trying to move a folder with just one picture causes Lr to freeze solid. I have removed all the 0 byte and trash folders. If there is no fix using Lr to move the folders, can I use the OS instead? How? Many Thanks!
      System Specs: Lr Ver 6.5; Win 10 Home; Intel i7-6700@4Ghz; 32GbRAM; GeForce GTX1070; OS on Samsung 500Gb SSD; Pics on WD 5Tb HDD
        • 1. Re: LR Freezes When Moving Folders
          ManiacJoe Adobe Community Professional
          Lightroom is not a file browser.
          Unfortunately, when trying to move large numbers of files, LR can sometimes drop the ball.
          Your best bet is to use Windows File Explorer to move your folders and files, without LR running.
          Then, in LR, go to the Folders panel in the Library module and do a "find missing" or "relocate" as needed.
          • 2. Re: LR Freezes When Moving Folders
            dj_paige Level 9
            Use your operating system to move the photos/folders, and then in Lightroom, follow these instructions to re-connect:
            Adobe Lightroom - Find moved or missing files and folders
            • 3. Re: LR Freezes When Moving Folders
              205EdMLewis Level 1
              I read through the documentation and it gives a good solution. I have discovered a few complications though.
              1. There are 2045 folders in the "Ed's Pics" directory. That's a lot of folders to move.
              2. The formats are different in the two directories. "Ed's Pics" is a single folder YYYY MM DD (no hyphens) while "Pictures" is YYYY / YYYY-MM-DD (with the parent folder for the year and hypens). This seems like the Lr default.
              3. I just discovered that many of the folder dates in "Ed's Pics" are out by one day from the creation date in the photos. I'm not sure how that happened or when.
              Would it make sense for me to do the following since I want all the photos to be in the "Pictures" directory format:??
              1. Save the Metadata to the files.
              2. Export the "Ed's Pic" directory to a different drive...not as a catalogue. OR just move it in the OS.?
              3. Remove the missing "Ed's Pics" directory and photos from Lr.
              4. Re-import the photos into Lr. They should then be added to the "Pictures" directory and in the correct folder format. I suspect that this method would also correct the one day offset as well.
              Many thanks for your thoughts.
              • 4. Re: LR Freezes When Moving Folders
                WobertC Adobe Community Professional
                NONE of the above!!!
                Do not attempt to export or re-import. This will only make more chaos.
                Follow the "Correct Answer" from DJ_Paige, and use the OS to 'move' the ENTIRE folder {Eds Pics} as a sub-directory into the {Pictures} directory. Then re-link the folder {Eds Pics} as advised by the info in the link given.
                Do not be concerned with the sub-folder structure. All your image searches for keywords, dates, etc, are easily handled by Lightroom.
                Folders are for "Storage", Lightroom Catalog is for "Data Management".
                • 5. Re: LR Freezes When Moving Folders
                  205EdMLewis Level 1
                  Very helpful, thank-you! I'm all for keeping it simple. The last part is good to know.
                  • 6. Re: LR Freezes When Moving Folders
                    dj_paige Level 9
                    This is all explained in the article at the link I gave. See Figure 4 and associated text.
                    The format of the folders is irrelevant, the solution works
