5 Replies Latest reply on Nov 20, 2017 8:38 AM by garrettb20873522
    Missing ease in function Graph edit handle
    ghazia38025826
      i'm using After effect 2017 when i goes and want to edit ease handle so handle doesn't appear please help to appear my handle to edit ease in speed Thank you
        • 1. Re: Missing ease in function Graph edit handle
          Bezier handles are only available on certain properties. In the graph editor press the g key to bring up the pen tool and then hover over any of the keyframes and hold down the Alt/Option key. I the pointer does not change to the convert point tool then try selecting a different graph type. If you still don't get a convert point tool (sideways V) then you have chosen a property that is not compatible with bezier controls.
          For more help, and better help, paste a PrintScreen screenshot of your entire AE window with modified properties the layers giving you problems selected and the composition selected in the Project Panel so we can see what's going on. If you are on a Mac then press Shift + Ctrl/Cmnd + 3 to take a full screenshot of the app and drag it from the desktop. If you are on Windows press PrintScreen and paste (Ctrl/Cmnd + v) so we can see what is going on.
          • 2. Re: Missing ease in function Graph edit handle
            ghazia38025826 Level 1
            Thank you so much for reply my problem question but my problem different.Look at this image i hope this time you understand what i say please tell me how can i active my graph editor handle which help to set ease in and ease out speed according to setting
            • 3. Re: Missing ease in function Graph edit handle
              If you right-click on the keyframe (back in the regular timeline) and choose ease in, and then go back to the graph editor, do you have a Bezier handle like you expect?
              • 4. Re: Missing ease in function Graph edit handle
                garrettb20873522 Level 1
                Hi Szalam,
                I'm having the same exact problem except I have two layers of the same type of image, both .ai assets.  The first one I applied easy ease in and out and the used the graph editor to adjust the handles, no problem.  Applied the exact same workflow to the second one and the handles are not available.
                So to answer your question for ghazia, the first time applying easy ease did work, the second time it did not for the same type of object and the same type of value (position).
                Any ideas? Thanks.
                • 5. Re: Missing ease in function Graph edit handle
                  I solved it but not in an informative way for other users.  I ended up copying the keyframes from the asset that did contain handles into the object that didn't and the handles appeared.  Still not sure what makes them available and what doesn't.
                  For those with this problem, try to find something that does have handles, copy and paste, then you can adjust them to that object's needs.
