3 Replies Latest reply on Feb 28, 2017 5:56 PM by Karl Heinz Kremer
    Adobe Export PDF,
      Bought this product so I could convert a PDF form to Word and type in it
      It converts badly plus I cant type in it
        • 1. Re: Adobe Export PDF,
          Karl Heinz Kremer Adobe Community Professional
          Converting from PDF to Word, Excel or any other format is one of the most complex things you can try to do with a PDF file. It works very well in some cases, in other cases the output has very little to do with the original file. The key for success is that the PDF file needs to be "tagged" - which means that it contains information about the information that is displayed in the file. The best way to make sure that a PDF file is tagged correctly is by using the PDFMaker in Acrobat to create the PDF file from Word or Excel (that's the Acrobat ribbon or toolbar).
          Unfortunately there is not much you can do to improve the output without spending a lot of time (e.g. by manually tagging the file). Also, if you are using Adobe's ExportPDF service and don't have access to Acrobat, that is not even an option.
          The only thing you can do is complain to the original author of the file and tell them that they used a bad PDF generator to create the PDF file.
          Sometimes it helps to save the PDF file as a set of high resolution (e.g. 600dpi) images, then import these images back into Acrobat, run OCR and then export to Word or Excel again. This would only be possible if you are using Adobe Acrobat and not the Export PDF online service.
          • 2. Re: Adobe Export PDF,
            tonyl71304379 Level 1
            In that case can I cancel my subscription since we signed up specifically to export pdf files to Word/Escel
            Cheryl Verghese
            Finance & Admin Officer
            Mudgee Local Aboriginal Land Council
            PO Box 1098,
            Mudgee, NSW 2850
            Phone: 02 63723511
            • 3. Re: Adobe Export PDF,
              You need to take that up with Adobe's support.
