1 Reply Latest reply on Feb 26, 2017 4:09 PM by try67
    How to add gender and age variables to my BMI calculation?
      I'm trying to build a calculator that works out the users BMI.
      I've managed to get this far at the moment, however I would like to add the users age and gender to the calculation.
      <!DOCTYPE html>
      <title>BMI Calculator</title>
          function computeBMI()
              //Obtain user inputs
              var height=Number(document.getElementById("height").value);
              var heightunits=document.getElementById("heightunits").value;
              var weight=Number(document.getElementById("weight").value);
              var weightunits=document.getElementById("weightunits").value;
              //Convert all units to metric
              if (heightunits=="inches") height/=39.3700787;
              if (weightunits=="lb") weight/=2.20462;
              if (heightunits=="cm") height/=100;
              //Perform calculation
              var BMI=weight/Math.pow(height,2);
              //Display result of calculation
              var output =  Math.round(BMI*100)/100
              if (output<18.5)
              document.getElementById("comment").innerText = "Underweight";
            else   if (output>=18.5 && output<=25)
              document.getElementById("comment").innerText = "Normal";
           else   if (output>=25 && output<=30)
              document.getElementById("comment").innerText = "Obese";
           else   if (output>30)
              document.getElementById("comment").innerText = "Overweight";
             // document.getElementById("answer").value = output;
      <h1>Body Mass Index Calculator</h1>
      <p>Enter your height: <input type="text" id="height"/>
          <select type="multiple" id="heightunits">
              <option value="metres" selected="selected">metres</option>
              <option value="inches">inches</option>
              <option value="cm">cm</option>
      <p>Enter your weight: <input type="text" id="weight"/>
          <select type="multiple" id="weightunits">
              <option value="kg" selected="selected">kilograms</option>
              <option value="lb">pounds</option>
      <input type="submit" value="computeBMI" onclick="computeBMI();">
      <h1>Your BMI is: <span id="output"></span></h1>
      <h2>This means you are: <span id="comment"></span> </h2>
