7 Replies Latest reply on Mar 1, 2017 6:55 AM by El Wombat
    Beard with dangle
    the_dovid Level 1
      I'm creating a character that has a big bushy dangly beard.  I plan on putting a bunch of dangles on different pieces of it.  But I also need it to move up and down with with the mouth.  I'm using a regular mouth, not a nutcracker.  So, here are the options as I see it (and I'm not happy with any of them):
      1. create duplicates of the beard on every mouth layer.  My concern here is that processing may get heavy.  Also, (assuming the dangle settings on each onstance are identical) would the dangle movement match exactly from frame to frame, or would they all be moving randomly on their own?
      2. put a nutcracker behavior on the beard.  I don't like this option because it may not match up exactly with what's happening with the viseme mouth. and i may end up with unexpected overlaps and such.
      Any thoughts on this?
        • 1. Re: Beard with dangle
          El Wombat Level 2
          it's not easy to tell from afar, but my first idea and suggestion would be a slight variation of 2.
          Create a jaw and give it a little nut-cracking. The dangling beard-strands, in an individual group, would be attached (stapled) to the jaw and then dangle. See this example: Character Animator Tips & Tricks (October 2016) - YouTube
          Then, as a general thought, try using only two, or three strands of beard. You can use more than one dangle on each strand, it doesn't have to be one for each strand only. It's less weight on your graphic processor and also more realistic, possibly, for a beard, unless it's rasta, doesn't normally come in so many strands as top hair.
          I've animated some bushes on a beach with that method to a nice effect. There was no time for individual grass strands, so that was a sort of "trick" solution, but in the end I found it to work perfectly. So that could look good:
          Try painting the different strokes and giving them dangle weights here and there, instead of going for uber-realism and animating each single hair (I'm exaggerating, but you get the picture…).
          • 2. Re: Beard with dangle
            El Wombat Level 2
            P.S.: "… try using only two, or three strands of beard…" or only one, but with said method…
            • 3. Re: Beard with dangle
              El Wombat Level 2
              3. you could also make "two" beards.
              a) One part, the chin-bone part, is part of your traditional lip-sync mouth - it's lower part, and it gets copied in every viseme.
              b) A second part, the "hairy" part, is of the same colour, of course, but consists only of those dangling strands, be it one, two, or 15, doesn't matter.
              That method would get rid of the nut-cracker jaw altogether and could also look good.
              • 4. Re: Beard with dangle
                oksamurai Employee Moderator
                Stefan has some great ideas! Personally I would do a test run of 2-3 mouth shapes and see what looks best for your character, because I think so much depends on what style you're going for.
                I do think copying a dangle beard for every mouth shape is going to get processor intensive and not get the result you're looking for. I believe dangles should carry through (I've added dangle to head turn hair before and it's looked okay) but it may feel jittery depending on how much the beard moves with each difference. Some kind of jaw solution is probably the safer bet, but it's worth experimenting with.
                • 5. Re: Beard with dangle
                  the_dovid Level 1
                  Thank you both for the thoughts.  Another idea I came up with after reading your suggestions:
                  Not every viseme is radically different in height than every other.  There are groups that are similar.  My thought is to make 2 or 3 beards (seperate from the mouth shapes)  and tag them as visemes (in addition to the actual mouths) with multiple tags per beard.
                  • 6. Re: Beard with dangle
                    Ah yes, that could work nicely too. Good luck!
                    • 7. Re: Beard with dangle
                      El Wombat Level 2
                      Happy "bearding"!
