6 Replies Latest reply on Mar 2, 2017 4:13 AM by lord.potato
    ink and slide with adobe draw
    lord.potato
      hello guys!
      i recently bought the ink and slide but i'm not able to connect it with my ipad. bluetooth is on, i try to use it with adobe draw (adobe line is not available in my country) but the ink won't connect..
      any ideas what i can do?
        • 1. Re: ink and slide with adobe draw
          Sue Garibaldi Adobe Employee (Admin)
          Hi LordPotato.
          Adobe Line is no longer in the AppStore, so don't worry about trying to use Ink with Draw. I do have a couple of questions:
          What version of Draw are you using and what device are you on?
          What happens when you try to connect?
          Are you getting an error message?
          Is the stylus working okay with other apps?
          Let me know so I can try to help.
          Sue.
          • 2. Re: ink and slide with adobe draw
            lord.potato Level 1
            Hello Sue.
            I just downloaded Draw today so i am asuming its the newest version and i have  an IPad Air (first generation).
            Whenever i turn the stylus on and put the tip on the big dot to connect it, nothing really happens (I hope you know what i am talking about). I even put my finger on the big connection dot and activated the stylus. The result was that it got connected but only for a short amount of time and i couldn't draw (it's like the tip of the stylus isn't working)
            Thanks for your help
            LordPotato
            • 3. Re: ink and slide with adobe draw
              LordPotato.
              Yep. I totally know what you're talking about. But... That's weird. Your finger will connect? But the stylus won't? I mean I suppose it could be "defective," but that seems like it would be unusual.
              Is it fully charged? Is it working with other apps?
              Sue.
              • 4. Re: ink and slide with adobe draw
                lord.potato Level 1
                yes you could say my finger connected..
                stylus is fully charged and i also tried to connect it with adobe sketch with the same result.
                it feels like the ipad won't register the tip at all (as i mentioned before i connected the stylus using my finger but when it got connected the tip still wasn't working).
                the ipad usually only register the tip when the stylus is on / connected right?
                • 5. Re: ink and slide with adobe draw
                  LordPotato.
                  Sorry for taking so long to respond.... I was asking around about problems with connecting Ink & Slide. None of the QE testers have seen any problems connecting Ink. I think it might be the stylus. Did you just buy it?
                  Just to double-check though, a couple of things to try:
                  * Try signing out of the app, restarting your device, and signing back in. See if you can connect.
                  * If you still can't connect it, if you've done any work, log in with your Adobe ID to Adobe Creative Cloud  to make sure it's synced to Creative Cloud then as long as your work is backed up, go ahead and uninstall the app and reinstall it. Then try to connect again.
                  Let me know what happens.
                  Sue.
                  • 6. Re: ink and slide with adobe draw
                    lord.potato Level 1
                    Hello Sue!
                    Yes i just bought it. I tried to connect it with another Ipad with the same result, it is obviously the stylus and i will return it. Thank you for your effort and help.
