Whenever I open Premiere Pro and try to use the SDK Panel I've created, I keep getting the notification: "Run Script Error: undefined is not an object". When I open Extendscript Toolkit, however, it functions fine. Do I have to finalize my project before it can run with just Premiere Pro, or what am I missing here?
Justin
Hi Justin,
You'll note that, at its root, PProPanel has a /PProPanel/PProPanel.jsx; that .jsx file is also referenced in the panel's manifest.
When the panel is loaded, that /PProPanel.jsx goes through every .jsx file in /PProPanel/jsx (in this case, just one such file), and loads it as available ExtendScript. Later, in response to user interaction, the panel calls into those ExtendScript functions, found in the .jsx files in the /jsx directory.
Does your panel use a similar mechanism?
[Feel free t
...Copy link to clipboard
Hi Justin,
[Feel free to send me the panel; b b b at adobe dot com]
Bruce,
Thanks for the insight. All the javascript functions are located in the .jsx file that's in the /PProPanel/jsx directory. Not totally sure why Premiere needs ExtendScript to be running in order to execute the functions properly. I'll send you the file I'm working with.
Justin
PPro doesn't; it also contains an ExtendScript interpreter.
BUT...
Any/all ExtendScript which is to be available during a given ExtendScript session / PPro session, must be within or enumerated from within the .jsx file specified in the panel's manifest.
So, don't send me just a .jsx file; rather, send me your entire panel.
For anyone else experiencing this problem, having built their panel from the sample panel, make sure that any elements you remove from your panel are also removed from the onLoaded() function. My problem was the onLoaded() function was trying to access the dragable control in the sample panel, which I had deleted. I kept getting "Undefined is not an object" errors when I would try to run my panel because the onLoaded() function was breaking before it could load ExtendScript and thus use all the functions I had made. The problem line for me that I had to remove was this:
document.getElementById("dragthing").style.backgroundColor = "lightblue";
Thanks for the help Bruce! And hope this can help someone.
