2 Replies Latest reply on Feb 28, 2017 2:47 AM by AngeloBot
    Adobe Photoshop CC 2015: Could not complete your request because of a program error
    AngeloBot
      While using Photoshop CC 2015 suddenly the power interrupted and when the power goes back I couldn't open the file that I'm currently working and it gives me an error 'Could not complete your request because of a program error.'
      I've checked my C:\Users[pcname]\AppData\Roaming\Adobe\Adobe Photoshop CC 2015\Adobe Photoshop CC 2015 Settings\PSErrorLog.txt
      Drop me some answer if you know this error and tell me how to fix this. Thanks a lot
      Here's what shows on my PSErrorLog.txt
      2017:02:28 16:46:11 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 16:47:37 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 16:48:24 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 16:48:52 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 16:54:15 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 16:55:48 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:01:48 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:05:44 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:08:17 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:08:58 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:10:46 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:17:31 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:18:24 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:19:08 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:22:01 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:27:32 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:27:45 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:30:50 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:32:12 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:32:38 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:40:53 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:58:03 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 17:58:56 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
      2017:02:28 18:06:29 : ..\..\sources\ULinkManager.cpp : 1402 : REQUIRE failed
