1 Reply Latest reply on Aug 15, 2008 1:36 PM by lmarden
    Images folder
    Lonno7 Level 1
      I've noticed that the images I used in my project tend to "pile up" in the Images folder, i.e., they don't go into the folder named after the topic in which they appear. Is it advisable or necessary to relocate images to their "proper" folder? If I do this, is there a problem with using the same image in different topics?
        • 1. Re: Images folder
          lmarden Level 2
          Hi Lon - you are right - RH doesn't stash them in folders as you select them for use on topics. You can, however, move them into images folders yourself. RH will keep track of the movement and retain the link to each topic it is used in.
          I believe this might even be part of the functionality of that pesky cpd file, but I could be wrong... no doubt someone will correct me if so!!
