3 Replies Latest reply on Mar 2, 2017 3:06 AM by Mr. Opus
    Can't enable plugin
    Mr. Opus
      I want to add cordova-open plugin.
      As described I installed it with
      $ cordova plugin add cordova-open
      But then my cordova.plugins object contains only barcodeScanner.
      How to enable cordova-open plugin?
        • 1. Re: Can't enable plugin
          kerrishotts Adobe Employee
          Are you waiting for "deviceready" before checking "cordova.plugins"?
          Can you see the plugin installed when you run "cordova plugins ls"?
          • 2. Re: Can't enable plugin
            Mr. Opus Level 1
            Here's my code:
            var app = {
                initialize: function () {
                    document.addEventListener('deviceready', this.onDeviceReady.bind(this), false);
                onDeviceReady: function () {
                    console.log(cordova.plugins);
            app.initialize();
            Yes, it's installed. This command outputs:
            cordova-open 1.0.12 "Open"
            cordova-plugin-compat 1.1.0 "Compat"
            cordova-plugin-file 4.3.1 "File"
            cordova-plugin-file-transfer 1.6.1 "File Transfer"
            cordova-plugin-whitelist 1.3.1 "Whitelist"
            • 3. Re: Can't enable plugin
              Mr. Opus Level 1
              document.plugins always contains only barcodeScanner except when I launch app in browser. Can't add plugins on iOS or Android. Tried it on Linux and OS X systems. All the same. Tried to create empty project or from template. Anyway doesn't matter.
