1 Reply Latest reply on Aug 23, 2008 2:25 AM by armgong
    can't compile flexbuilder 3.0.1 datavisualization code
    armgong
      when use flexbuilder 3.0.1 , ant datavisualization -file dmv_automation_build.xml ,it show following errors:
      anyone can solve this problem? because we need to change datavisualization code.
      BTW We copy the fbpro(3.0.1) source dir to flex builder 3.0.0 and can build it under flex sdk 3.0.0.
      Buildfile: dmv_automation_build.xml
      [echo] Please set the environment variable ANT_OPTS to -Xmx256m
      [echo] flex_home c:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\fbpro/..
      datavisualization:
      [compc] Loading configuration file C:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\frameworks\flex-config.xml
      [compc] C:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\fbpro\projects\datavisualization\src\ChartsClasses.as(1): col: 1 Error: The definition of base class Object was not found.
      [compc]
      [compc] /*************************************************************************
      [compc] ^
      [compc]
      [compc] C:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\fbpro\projects\datavisualization\src\mx\collections\SummaryField.as(1): col: 1 Error: The definition of base class Object was not found.
      [compc]
      [compc] ////////////////////////////////////////////////////////////////////////////////
      [compc] ^
      [compc]
      many errors like above
