Hi
for example, if I use "bevel and Emboss" on several of my layers and make a change in one of these layers, then automatically changes all the layers that have the same effect.
How can I use "layer effects" on several layers, but without the influence each other, want to use layer effect that use/have the same function but with different settings.
steenmikkelsen2 wrote
Hi
How do you do that. ? That not the way layer style are rendered.
Layer styles are rendered for the layer they are on not other layers.
Layer style on a group are rendered for the groups composite not the layers in the group sometimes it may look like they are rendered for the layers in the group bu
...Copy link to clipboard
Hi
Layer style on a group are rendered for the groups composite not the layers in the group sometimes it may look like they are rendered for the layers in the group but that is not the case. Look at this example where the layers contents overlap. You can clearly see that they are being rendered for the layers composite. If the layers contents do not overlap it would look like there rendered for each layer in the group.
UNcheck Use Global Light
