6 Replies Latest reply on Mar 1, 2017 1:00 PM by Steve Grisetti
    Audio is out of sync with video after saving a project
    june62
      Audio is out of sync with video after saving a project. I have a PC, using Windows 10. I have no problems editing and creating a video from a standard movie, except on playback the audio precedes the video by about 1-2 seconds on every scene. I have tried various video  and audio resolutions and formats with no success, including AAC, WAV, MP3, and MP4, MPEG-TS. Would appreciate an solution to this issue.
      Thank you.
      June62
        • 1. Re: Audio is out of sync with video after saving a project
          What model of camcorder is your original footage coming from and what format and resolution is this video?
          This issue is most common with non-camcorder video that uses a variable frame rate.
          • 2. Re: Audio is out of sync with video after saving a project
            june62 Level 1
            The movie is non-camcorder. I don't know the format but it is a high-def movie that I down-loaded from the net.
            • 3. Re: Audio is out of sync with video after saving a project
              Downloaded from the net can be anything.
              If you do not provide exact info we are not able to help you.
              Might just want to buy the movie saves a lot of trouble.
              • 4. Re: Audio is out of sync with video after saving a project
                Please download the free program Media Info and open your video in it.
                Set Media Info's View menu to Tree and copy the information to this forum. This will give us the information we need in order to help you.
                • 5. Re: Audio is out of sync with video after saving a project
                  june62 Level 1
                  Steve,I hope this is the info you requested. If the problem is a variable frame rate, can Adobe Premiere create a clip in which the audio and video are in sync?Harry
                  General
                  Complete name :
                  N:\VIDEOS DIGITIZED 2016-2017\Medical\Movies, mainstream\The Color of Night - Bruce Willis.mp4
                  Format :
                  MPEG-4
                  Format profile :
                  Base Media / Version 2
                  Codec ID :
                  mp42 (mp42/mp41)
                  File size :
                  1.20 GiB
                  Duration :
                  7 min 37 s
                  Overall bit rate mode :
                  Variable
                  Overall bit rate :
                  22.4 Mb/s
                  Encoded date :
                  UTC 2017-02-28 06:57:17
                  Tagged date :
                  Video
                  ID :
                  1
                  Format :
                  AVC
                  Format/Info :
                  Advanced Video Codec
                  Format profile :
                  Main@L4.2
                  Format settings, CABAC :
                  Yes
                  Format settings, ReFrames :
                  3 frames
                  Format settings, GOP :
                  M=4, N=29
                  Codec ID :
                  avc1
                  Codec ID/Info :
                  Advanced Video Coding
                  Duration :
                  7 min 37 s
                  Source duration :
                  7 min 37 s
                  Bit rate mode :
                  Variable
                  Bit rate :
                  22.3 Mb/s
                  Maximum bit rate :
                  40.0 Mb/s
                  Width :
                  1 440 pixels
                  Height :
                  1 080 pixels
                  Display aspect ratio :
                  16:9
                  Frame rate mode :
                  Constant
                  Frame rate :
                  29.970 (30000/1001) FPS
                  Standard :
                  NTSC
                  Color space :
                  YUV
                  Chroma subsampling :
                  4:2:0
                  Bit depth :
                  8 bits
                  Scan type :
                  Progressive
                  Bits/(Pixel*Frame) :
                  0.478
                  Stream size :
                  1.19 GiB (99%)
                  Source stream size :
                  1.19 GiB (99%)
                  Language :
                  English
                  Encoded date :
                  Tagged date :
                  Color range :
                  Limited
                  Audio
                  ID :
                  2
                  Format :
                  AAC
                  Format/Info :
                  Advanced Audio Codec
                  Format profile :
                  LC
                  Codec ID :
                  40
                  Duration :
                  7 min 37 s
                  Source duration :
                  7 min 38 s
                  Bit rate mode :
                  Variable
                  Bit rate :
                  157 kb/s
                  Maximum bit rate :
                  252 kb/s
                  Channel(s) :
                  2 channels
                  Channel positions :
                  Front: L R
                  Sampling rate :
                  48.0 kHz
                  Frame rate :
                  46.875 FPS (1024 spf)
                  Compression mode :
                  Lossy
                  Stream size :
                  8.59 MiB (1%)
                  8.59 MiB (1%)
                  Language :
                  English
                  Encoded date :
                  Tagged date :
                   Harry Ardolino M.D.
                  • 6. Re: Audio is out of sync with video after saving a project
                    Variable frame rate. Just as I suspected.
                    The easiest solution is to convert the file to a new MP4 using the free download Handbrake. Use the specs MP4, 1920x1080 at 29.97 (or 30) fps -- and Constant Frame Rate.
                    The video you output from Handbrake will work perfectly in Premiere Elements.
