5 Replies Latest reply on Mar 2, 2017 1:01 AM by davidl28784412
    Lightroom will not connect
    davidl28784412
      When trying to use lightroom I get a message stating something along the lines of " lightroom cannot connect as it is already running in another application. Then the options , choose another catalogue, continue , exit.
      This is driving me nuts as I cannot use the software. Please help !
        • 1. Re: Lightroom will not connect
          Just Shoot Me Adobe Community Professional
          Look in the folder where the catalog file is stored for a .lock file. Delete that .lock file. Do this with LR closed then try to open LR.
          • 2. Re: Lightroom will not connect
            davidl28784412 Level 1
            I have looked through all my photo files and can't seem to find anything.
            Could it be somewhere else ?
            Thank you
            • 3. Re: Lightroom will not connect
              The Catalog files isn't usually with your images. Do a search for .LRCAT (.lrcat). If you find any look at the folders they are in for a .lock file. Have LR closed when doing that. Delete the .lock file.
              Or better yet just search for .lock.
              • 4. Re: Lightroom will not connect
                DdeGannes Adobe Community Professional
                Look in My Pictures( Win) / Pictures ( Mac) >Lightroom, You should see a file there that has an extension .lrcat (LRCAT), that is your Catalog File.
                Check if there is also a file with the same name ending with the extension .lock (LOCK) and delete this file if it is present, do not delete any other files in the Lightroom sub folder.
                When lightroom is open it creates a temporary file next to the Catalog file that is open with the lock extension to prevent any other use of the Catalog file. If Lightroom is shut down normally this lock file is automaticall deleted, However if Lightroom is shut down abnormally i.e. crash or power off the lock file may remain in place and will prevent Lightroom from reopening.
                • 5. Re: Lightroom will not connect
                  I have now got Lightroom back to an extent but it will only open through a
                  file described as Lightroom Catalogue but the icon on my desktop has now
                  turned into a blank file with no LR logo that just looks like a sheet of
                  paper with one corner turned down. Excuse my layman's terms but easy to
                  describe that way. I can live with this as I have pulled the Lightroom
                  Catalogue to the desktop to work from there. Just preferred it as it was
                  originally. Should I uninstall then reinstall ? I subscribe monthly so
                  unsure if this would work. Thank you
