I have installed adobe air(version: 24.0.0.180) in my pc. Then i have tried to install air application. but showing this below message
"The application could not be installed because the installer file is damaged. Try obtaining a new installer file from the application author."
Here is my installation log file:
[2017-03-01:15:03:34] Runtime Installer begin with version 24.0.0.180 on Windows 7 x86
[2017-03-01:15:03:34] Commandline is:
[2017-03-01:15:03:34] No installed runtime detected
[2017-03-01:15:03:37] Relaunching with elevation
[2017-03-01:15:03:37] Launching subprocess with commandline c:\users\kabbojsr\appdata\local\temp\aire82d.tmp\adobe air installer.exe -ei
[2017-03-01:15:03:39] Runtime Installer begin with version 24.0.0.180 on Windows 7 x86
[2017-03-01:15:03:39] Commandline is: -stdio \\.\pipe\AIR_3428_0 -ei
[2017-03-01:15:03:39] No installed runtime detected
[2017-03-01:15:03:39] Starting silent runtime install. Installing runtime version 24.0.0.180
[2017-03-01:15:03:40] Installing msi at c:\users\kabbojsr\appdata\local\temp\aire82d.tmp\setup.msi with guid {63B5DA5A-477B-438D-A6A0-118787A4C71B}
[2017-03-01:15:03:43] Runtime Installer end with exit code 0
[2017-03-01:15:03:43] Elevated install completed
[2017-03-01:15:03:45] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2017-03-01:15:03:45] Runtime Installer end with exit code 0
[2017-03-01:15:03:46] Runtime Installer begin with version 24.0.0.180 on Windows 7 x86
[2017-03-01:15:03:46] Commandline is: -installupdatecheck
[2017-03-01:15:03:46] Installed runtime (24.0.0.180) located at c:\Program Files\Common Files\Adobe AIR
[2017-03-01:15:03:47] Performing pingback request
[2017-03-01:15:03:47] Failure during pingback request: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032" errorID=2032]
[2017-03-01:15:03:47] Runtime Installer end with exit code 0
[2017-03-01:15:04:29] Application Installer begin with version 24.0.0.180 on Windows 7 x86
[2017-03-01:15:04:29] Commandline is: "D:\Web Development Softwares\Crunch.1.9.3.air"
[2017-03-01:15:04:29] Installed runtime (24.0.0.180) located at c:\Program Files\Common Files\Adobe AIR
[2017-03-01:15:04:30] Unpackaging file:///D:/Web%20Development%20Softwares/Crunch.1.9.3.air to C:\Users\kabbojsr\AppData\Local\Temp\flaD9C1.tmp
[2017-03-01:15:04:37] Package signature validation failed
[2017-03-01:15:04:37] Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="invalid package signature" errorID=5022]
[2017-03-01:15:04:50] Application Installer end with exit code 7
How can i fix this problem?
kindly help please
Could you try using the latest installer available on Adobe - Adobe AIR page and see if you still face any issues.
Thanks!
I'm getting this too and I've tried EVERYTHING. HELP!!!!!!
Hello,
I installed Adobe Air version 27.0.0.124.
I downloaded settingsmanager.air on the adobe site but when I want to install it I get a "Package signature validation failed".
How can I install it?
