I would like to trigger two animations on a single on-click(Self) event. This will be a box once clicked on a image fades in and the box's text changes. I can't convert the box into a button because they don't work very good on mobile. The way I was thinking about doing this is, exporting the two animations as a snippet and combining the two animations with one trigger event. I'm not quite sure on how to link the two animations to the same trigger event.
What kind of output are you attempting? Are you using InDesign CC 2017?
After I finish editing the snippet I will place it back into the document then publish online. Yes Indesign CC 2017
Could you be a little more detailed as to what you want to do.
I am creating a interactive organizational chart that can be viewed on desktop and mobile device. When a box on the chart gets clicked on, the box's job title will change to employee name and date of hire. At the same time a picture of the employee will fade-in to the right of the box and grow. After 3 secs the box resets so it can be clicked again (the image will shrink left, fade-out and the box will show the job title again).
So far the only way I could think of that will work on both desktop and mobile devices is using InDesign CC publish online. I tried using buttons but they don't seem to be very responsive on android sometime require double or triple tabs to trigger event.
