5 Replies Latest reply on Mar 3, 2017 8:48 AM by rob day
    FindChangeByList.applescript inserts a wrong character
    slobodant27167858
      I'm running a query via FindChangeByList.applescript and one line in text configuration file ultimately tries to insert a string containing the "ø" character. However, what ends up in InDesign CS6 text is "√∏" instead of the above character. What is going on, can anyone help?
        • 1. Re: FindChangeByList.applescript inserts a wrong character
          Michael Witherell Adobe Community Professional
          Why don't you post the script for us to see it?
          • 2. Re: FindChangeByList.applescript inserts a wrong character
            Sandee Cohen Adobe Community Professional
            Mike,
            This is the script that comes with the Samples for the Scripts panel. The script is:
            --FindChangeByList.applescript
            --An InDesign AppleScript
            --Loads a series of tab-delimited strings from a text file, then performs a series
            --of find/change operations based on the strings read from the file.
            --The data file is tab-delimited, with carriage returns separating records.
            --The format of each record in the file is:
            --findType<tab>findProperties<tab>changeProperties<tab>findChangeOptions<tab>description
            --Where:
            --<tab> is a tab character
            --findType is "text", "grep", or "glyph" (this sets the type of find/change operation to use).
            --findProperties is a properties record (as text) of the find preferences.
            --changeProperties is a properties record (as text) of the change preferences.
            --findChangeOptions is a properties record (as text) of the find/change options.
            --description is a description of the find/change operation
            --Very simple example:
            --text {find what:"--"} {change to:"^_"} {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false} Find all double dashes and replace with an em dash.
            --More complex example:
            --text {find what:"^9^9.^9^9"} {applied character style:"price"} {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false} Find $10.00 to $99.99 and apply the character style "price".
            --All InDesign search metacharacters are allowed in the "find what" and "change to" properties.
            --For more on InDesign/InCopy scripting see the documentation included in the Scripting SDK
            --available at http://www.adobe.com/devnet/indesign/sdk.html
            --or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
            tell application "Adobe InDesign CC 2015"
              --Set the user interaction level to allow InDesign to display dialog boxes and alerts.
              set user interaction level of script preferences to interact with all
              set myTextObjects to {text, text frame, insertion point, character, word, text style range, line, paragraph, text column, cell, table, row, column}
              if (count documents) is not 0 then
              if (count stories of active document) is not 0 then
              set mySelection to selection
              if (count mySelection) is not 0 then
              if class of item 1 of mySelection is in myTextObjects then
              if class of item 1 of mySelection is text frame then
              set myObject to object reference of text 1 of item 1 of mySelection
              else if class of item 1 of mySelection is insertion point then
              set myObject to parent story of item 1 of mySelection
              else
              set myObject to item 1 of mySelection
              end if
              my myDisplayDialog(myObject, myTextObjects)
              else
              set myObject to active document
              end if
              else
              my myFindChangeByList(myObject)
              end if
              else
              display dialog ("The current document contains no text. Please open a document containing text and try again.")
              end if
              else
              display dialog ("No documents are open. Please open a document and try again.")
              end if
            end tell
            on myDisplayDialog(myObject, myTextObjects)
              if class of myObject is insertion point then
              set myObject to parent story of myObject
              end if
              set myDialog to make dialog with properties {name:"FindChangeByList"}
              tell myDialog
              tell (make dialog column)
              set myRangeButtons to make radiobutton group
              tell myRangeButtons
              make radiobutton control with properties {static label:"Entire document", checked state:true}
              make radiobutton control with properties {static label:"Selected story"}
              if class of myObject is in myTextObjects and class of myObject is not insertion point then
              set myContents to contents of myObject
              if myContents is not equal to "" then
              make radiobutton control with properties {static label:"Selection", checked state:true}
              end if
              end if
              end tell
              end tell
              end tell
              set myResult to show myDialog
              if myResult is true then
              set myRange to selected button of myRangeButtons
              destroy myDialog
              if myRange is 0 then
              set myObject to document 1
              else if myRange is 1 then
              if class of myObject is not story then
              end if
              end if
              else
              destroy myDialog
              end if
              end tell
            end myDisplayDialog
            on myFindChangeByList(myObject)
              local myFile, myFileRef, myEOF, myFindType
              set myFile to my myFindFile("FindChangeSupport:FindChangeList.txt")
              set myFileRef to open for access (myFile as alias)
              set myEOF to get eof myFileRef
              set myOldDelimiters to AppleScript's text item delimiters
              --That's a tab character between the quotation marks in the next line.
              set AppleScript's text item delimiters to {" "}
              if myEOF > 0 then
              --Delimiter is return--if you have trouble reading your find/change file, it's
              --probably because your line end characters are not Mac OS line end characters.
              set myText to read myFileRef using delimiter {return}
              close access myFileRef
              repeat with myCounter from 1 to (count myText)
              set myLine to item myCounter of myText
              if myLine starts with "text" or myLine starts with "grep" or myLine starts with "glyph" then
              if word 1 of myLine is "text" or word 1 of myLine is "grep" or word 1 of myLine is "glyph" then
              set {myFindType, myFindPreferences, myChangePreferences, myFindChangeOptions, myDescription} to text items of myLine
              if myFindType is "text" then
              my myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              else if myFindType is "grep" then
              my myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              else if myFindType is "glyph" then
              my myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              end if
              end if
              end if
              end repeat
              end if
              set AppleScript's text item delimiters to myOldDelimiters
              end tell
            end myFindChangeByList
            on myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              --Clear the find text/change text preferences before each find/change operation.
              set find text preferences to nothing
              set change text preferences to nothing
              set myScript to "tell application \"Adobe InDesign CC 2015\"" & return & "set properties of find text preferences to " & myFindPreferences & return
              set myScript to myScript & "set properties of change text preferences to " & myChangePreferences & return
              set myScript to myScript & "set properties of find change text options to " & myFindChangeOptions & return
              set myScript to myScript & "end tell" & return
              do script myScript language applescript language
              tell myObject
              set myFoundItems to change text
              end tell
              --Clear the find text/change text preferences after each find/change operation.
              end tell
            end myFindText
            on myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              --Clear the find grep/change grep preferences before each find/change operation.
              set find grep preferences to nothing
              set change grep preferences to nothing
              set myScript to "tell application \"Adobe InDesign CC 2015\"" & return & "set properties of find grep preferences to " & myFindPreferences & return
              set myScript to myScript & "set properties of change grep preferences to " & myChangePreferences & return
              set myScript to myScript & "set properties of find change grep options to " & myFindChangeOptions & return
              tell myObject
              set myFoundItems to change grep
              end tell
              --Clear the find grep/change grep preferences after each find/change operation.
              end tell
            end myFindGrep
            on myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
              --Clear the find glyph/change glyph preferences before each find/change operation.
              set find glyph preferences to nothing
              set change glyph preferences to nothing
              set myScript to "tell application \"Adobe InDesign CC 2015\"" & return & "set properties of find glyph preferences to " & myFindPreferences & return
              set myScript to myScript & "set properties of change glyph preferences to " & myChangePreferences & return
              set myScript to myScript & "set properties of find change glyph options to " & myFindChangeOptions & return
              tell myObject to change glyph
              --Clear the find glyph/change glyph preferences after each find/change operation.
              end tell
            end myFindGlyph
            on myFindFile(myFindFileName)
              try
              set myScript to active script
              on error
              set myScript to path to me
              end try
              end tell
              tell application "Finder"
              set myScript to file myScript
              set myParentFolder to (container of myScript) as string
              set myFileName to myParentFolder & myFindFileName
              set myResult to exists myFileName
              else
              set myFileName to choose file with prompt "Locate your find/change file"
              end if
              end tell
              return myFileName
            end myFindFile
            • 3. Re: FindChangeByList.applescript inserts a wrong character
              Hi Sandee,
              I got the impression that the OP had a modified script, but I don't really know.
              Best to you,
              Mike
              • 4. Re: FindChangeByList.applescript inserts a wrong character
                vinny38 Level 5
                Hi
                Use GREP pattern \x{UNICODE} in your FindChangeList.txt file.
                Don't forget to escape the antislash:
                grep{findWhat:"your query"}{changeTo:"\\x{00f8}"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}
                Example:
                • 5. Re: FindChangeByList.applescript inserts a wrong character
                  Sandee, the FindChangeByList script (both AppleScript and Javascript versions) expect you to edit the companion .txt file (FindChangeList.txt), which is a list of grep or text find and changes. Vinny is showing the text edit needed—the text list is actually script code so an edit can break the script if it is not done correctly.
