4 Replies Latest reply on Mar 4, 2017 8:40 AM by karth80472045
    Text frame Transform
    karth80472045 Level 1
      Hello everyone,
      i have a doubt what is use of method translate or transform.
      suppose i am having a text frame how to move this text frame if is an point type text.
          1
      star text is located down 1 is located above how to move this star close to 1 like *1 can anybody explain me with an example.
      with regards,
      yuvi
        • 1. Re: Text frame Transform
          Ten A Adobe Community Professional
          Reference each geometrical position. In this case, You can use thte geometricBounds property and the width property like below
          var pos = app.activeDocument.textFrames[0].position;
          app.activeDocument.textFrames[1].position
            = [pos[0] - app.activeDocument.textFrames[1].width,
            app.activeDocument.textFrames[0].position[1]];
          • 2. Re: Text frame Transform
            Thanks for the reply ,
            here is my requirement
            i have also written code
            read_star(activeDocument.groupItems);
            function read_star(Grps)
               var lay_i, txt_i, x, y, xx, xy, count, txtFramesLen, t, t1;
                for (lay_i = 0; lay_i < Grps.length; lay_i++) {
                if (Grps[lay_i].locked) Grps[lay_i].locked = false;
                if (Grps[lay_i].name != "NUMBER") continue;
                 txtFramesLen = Grps[lay_i].textFrames.length;
                 for (txt_i = txtFramesLen - 1; txt_i >= 0; txt_i--) {
                    var text_frame = Grps[lay_i].textFrames;
                        if(text_frame[txt_i].characters.length==1)
                          if(text_frame[txt_i].textRange.characterAttributes.size==14 ||text_frame[txt_i].textRange.characterAttributes.size==12)
                              if(text_frame[txt_i].contents=="*")
                            text_frame[txt_i].textRange.characterAttributes.size=7.5;
                              t7  = Math.round(text_frame[txt_i].anchor[1]);
                    t8 = (Math.round(text_frame[txt_i].anchor[0]));
                    else
                        continue;
                 for (txt_i1 = txtFramesLen - 1; txt_i1 >= 0; txt_i1--) {
                   if(text_frame[txt_i1].characters.length==1)
                        if(text_frame[txt_i1].contents!=text_frame[txt_i].contents)
                                      if(text_frame[txt_i1].contents.match==(/[0-9]{1}$/))
                            t9  = Math.round(text_frame[txt_i1].anchor[1]);
                    t10 = (Math.round(text_frame[txt_i1].anchor[0]));
                    t11=t10-1;
                     var tm2= new Matrix();
              tm2.mValueA = 1;
            tm2.mValueB = 0;
            tm2.mValueC = 0;
            tm2.mValueD = 1;
              tm2.mValueTX = t11;
            tm2.mValueTY = t9;
            text_frame[txt_i].transform(tm2,true,true,true,true,1);
            this is my code but i could not pass t11, t9 value inside matrix
            • 3. Re: Text frame Transform
              can you make corrections in my code sir
              • 4. Re: Text frame Transform
                hello sir ,
                still i am facing this problem !! can you help me?
