Hello,
I have video file (.mov) which I exported from Premier pro 1280 x 720, 50 fps. , length 2:30 seconds. I need to update subtitle in this video but its frustrating that video is playing very slow in Composition in After effect 2017. Yesterday, I spent my all day to read all technical things to improve performance to play it smoothly in after effect but luck did not work. I have my Lenovo Laptop Z51
System Details:
Window 8.1
Processor: Intel (R) Core (TM) i5-5200 CPU @ 2.20GHz 2.20 GHz
Ram: 8GB
System Type: 64-Bit Operating System, x64-bassed processor
C: Drive Total Memory 525 GB
C: Drive Free Memory 329 GB
Open GL - ( According to After Effect/Preference/Preview/ Gpu information )
Vendor: ATI Technologies Inc.
Device: AMD RADEON (TM) R9 M375
Version: 3.0.13469 Compatibility Profile Context 21.19
I can not work in slow mode, I did not buy after effect to work in slow mode. I am very much frustrated that my work got to be pending because of it. Please Adobe Team Help me. Any more information, I will give you.
Javed ( Waiting curiously )
Now, you DO understand that AE doesn't play video like PP, correct?
You DO understand that previewing instead of hitting the space bar is the norm, correct?
Yes, I know AE can't play video smoothly like PP but it is very much slow, like too slow. If I have healthy configuration in my laptop then why I have to suffer this much. I need to do so many things in after effect in coming future, I can not use it in this much slow mode. Please help me.
In previewing and hitting space bar, both are giving same slow mode playback performance ?
For subtitle work, I usually recommend Premiere. It has actual subtitle tools, but even if you're just adding text over top of things, it's a lot faster than After Effects.
That being said, the problem might be in the codec you output from Premiere Pro. What were your export settings?
Thank you for reply, Actually I want to use animation with my text, and I need to do some oher work on AE
These are my export setting on PP:
Format: H.264
Preset: Custom
Output Name: MVI_9878_2.mp4
Basic Video Setting: ( Showing Exporting Board is 😞
Width & Height: 1280 x 720
Frame Rate: 50
Field Order: Progressive
Aspect: Square Pixels (1.0)
TV Stabdard: Pal
Bitrate Setting:
Target Bitrate: 10
Maximum Bitrate: 12
Audio Format:
Audio Format: AAC
Audio Codec: AAC
Sample Rate: 48000 Hz
Channels : Stereo
Audio Quality: High
Bitrate: 320
Please help me more
Hi Javed,
Did you ever solve this issue? If so, how did you do it? Please let us know.
Kevin
