10 Replies Latest reply on Mar 7, 2017 11:52 AM by Vinícius Amaral
    Socket object
    Vinícius Amaral Level 1
      Hello there
      I´m trying to learn how to connect the InDesign with a web page for a future project.
      Now I´m using the sample code released for Adobe at the JavaScript Tools Guide, but all my tries was unsuccessful.
      I cold not connect with any page, server and bla, bla, bla.
      Check the below code (exactly as in Adobe reference document)
      reply = "";
      conn = new Socket;
      // access Adobe’s home page
      if (conn.open ("www.adobe.com:80")) {
      // send a HTTP GET request
      conn.write ("GET /index.html HTTP/1.0\n\n");
      // and read the server’s reply
      reply = conn.read(999999);
      conn.close();
      Anyone can help me?
      PS.: I´ve read a lot of topcs, articles and tutorials about this subject and all my tests was unsucessful.
        • 1. Re: Socket object
          Loic.Aigon Adobe Community Professional
          I could never get it to myself to work neither but I think I read other fellows around did so it's likely you should find some snippets already in the forum.
          FWIW, the only times i had to retrieve data from http,I used getUrl from Rorohiko, it works like a charm:
          Rorohiko: July 2008
          HTH
          Loic
          • 2. Re: Socket object
            Hi Vinicius,
            see also this thread where several methods are discussed:
            Is it possible to load web content?
            FWIW and it might not apply in your case:
            For downloading e.g. an image from a dropbox account I had success with a combined AppleScript/ExtendScript method using curl services that are implemented with OSX.
            Regards,
            Uwe
            • 3. Re: Socket object
              Ronald63 Level 4
              Hello,
              Try this snippet (not working with "www.adobe.com")
              var conn = new Socket;
              var host =  "www.indesignjs.de";
              var cmd = "GET /index.html HTTP/1.1\r\nHost:"+host+"\r\n\r\n";
              var reply='';
              conn.timeout = 100;
              if (conn.open (host +':80', 'BINARY')) {
                      conn.write (cmd);
                      while (conn.connected && ! conn.eof) {
                         reply += conn.read(1024) + "\n";
                      conn.close();
                      alert(reply);
              Good luck ;-)
              • 4. Re: Socket object
                Dear Loic.Aigon
                First of all, thanks for your attention.
                I've seen before a lot of designners/programmers getting successful tests with this snnipet code that you mentioned. I think if I try, I will also could.
                I wish do something with the Socket object, but if I couldn´t I will use the Rorohiko tools.
                Thanks a lot
                • 5. Re: Socket object
                  Hi Laubender
                  I just need to access a TXT or XML file.
                  I believe the Rorohiko solution works fine, but I wanna know why the Adobe´s solution doesn´t.
                  If I could not fix this issue I will use the Rorohiko.
                  Best regards
                  • 6. Re: Socket object
                    Hello Ronald
                    I´ve tryed to use your code, but the variable returns me nothing.
                    Have you returned anything?
                    When I check the connection, it retuns me false
                    It is an official document from Adobe.
                    I can´t believe it not will gonna work.
                    • 7. Re: Socket object
                      Ronald63 Level 4
                      I get a reply ... (Testing with MacOS 10.12.3 - InDesign CC2014).
                      If you are on Windows, maybe a problem with the anti-virus or firewall.
                      • 8. Re: Socket object
                        I can confirm what Ronald says.
                        I'm on Mac OSX using InDesign CC 2017 and ran the script snippet from the ESTK.
                        It returned:
                        HTTP/1.1 200 OK
                        Date: Sat, 04 Mar 2017 13:00:35 GMT
                        Server: Apache/2.4.18 (Ubuntu)
                        Last-Modified: Thu, 30 Jul 2015 11:55:00 GMT
                        ETag: "e3-51c165f764d00"
                        Accept-Ranges: bytes
                        Content-Length: 227
                        Vary: Accept-Encoding
                        Content-Type: text/html
                        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
                        <html><head><meta http-equiv=Refresh content="0;url=/auflage2/"></head>
                        <body>
                        <a href="auflage2/index.php">2. Auflage InDesign automatisieren</a>
                        </body>
                        </html>
                        Seems the file is by Gregor Fellenz.
                        Regards,
                        Uwe
                        • 9. Re: Socket object
                          Hi Ronald
                          Thanks for your help.
                          I also have one Mac and it is working,
                          Now I have to figure out why is not working on PC in my companny.
                          I don't think it is because a possible firewall.
                          I will keep in contact.
                          • 10. Re: Socket object
                            Perfect Laubender
                            Now I have a new task...
                            Why it is not working on my PC.
                            I will get an other internet link and try it again.
                            Thanks for your attention.
