31 Replies Latest reply on Nov 15, 2018 4:57 PM by ryzanshine
    fontea plugin woes
    StrongBeaver Level 3
      Has anyone attempted to install the plugin fontea for Photoshop ? It creates a folder that begins with com although when placed in the Program Files > PhotoshopCC 2017 > Plugins folder it doesn't get loaded when starting Photoshop ?
        • 1. Re: fontea plugin woes
          S_Gans Adobe Community Professional
          Hi. I installed this on my Mac. It doesn't create a regular plugin - it's actually found in the Window>Extensions folder. The files that got created were in my User folder - and in there, you'd find the com.madebysource.fontea folder in the Windows equivalent of the Application Support>Adobe>CEP>Extensions folder and I seem to also have one that's just mainly in the Application Support folder - free-floating. There's also a Fontea folder in the Application Support folder
          I didn't extract it - I used the installer, itself. Didn't your .exe file for the download have an installer in it?
          • 2. Re: fontea plugin woes
            Jeff Arola Adobe Community Professional
            Yes, it's under Window>Extensions as S.Gans said above.
            Photoshop cc 2017.0.1 on win 10 x64 shown below.
            • 3. Re: fontea plugin woes
              Trevor.Dennis Adobe Community Professional
              I tried it and it showed up straight away in the Window > Extension menu, but I had to install it twice before the fonts displayed with correct previews, and clicking on any of the fonts brings up an error message, so I don't have it working so far.   Has anyone actually read the instructions?
              • 4. Re: fontea plugin woes
                When I originally installed the extension via the installation method of the extension it installed its self in \Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins @S_Gans brought to my attention this path \Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions.  Therefore I moved the folder beginning with COM to the second path; restarted Photoshop and nothing continues to be listed under Window > Extension ?
                • 5. Re: fontea plugin woes
                  I've found that you can't select a font before you have the text you want to convert to that font. If I select a font without text, I get your error above, if I select text, or a text layer, and then choose a font, it syncs and changes that font.
                  • 6. Re: fontea plugin woes
                    I'd say don't move the files - copy them. They were in BOTH places. Now, it may be because I have multiple versions of Photoshop installed, so I can't answer which location is appropriate to your setup - but I do have the files in both locations for it to work.
                    • 7. Re: fontea plugin woes
                      At one point today, I did have the files in both locations @S_Gans.  After re-installing the extension, it may have been the third time;  I do not see fontea in my Windows > Extension list.
                      • 8. Re: fontea plugin woes
                        That works for me, and makes it a pretty worthwhile extension.
                        • 9. Re: fontea plugin woes
                          I'm sorry. I'm on the MacOS, not Windows, so I can't make further suggestions as to additional places the files may need to be on your OS. Perhaps the developer may help. Their tech support is at: team@madebysource.com
                          • 10. Re: fontea plugin woes
                            madebysource doesn't give support for free extensions.
                            • 11. Re: fontea plugin woes
                              Perhaps someone on here with Windows can then make a suggestion. Which version of windows are you using, as it looks like the installer did work for others with Windows on this thread.
                              You say you've reinstalled it at least 3 times? May I suggest you search all your library files for anything associated with the extension and delete everything that hints at the words fontea or madebysource. Then, reset Photoshop preferences and then try the installation again. Looks like at least 1 or 2 of your regular installations did put files where they belong, but with all these attempts and manual moving, the files got in too many places for your Photoshop to know where to find them?
                              Otherwise, there's always the nuclear version... to uninstall all extensions, back up your plugins folder, and then use the Adobe Uninstaller Tool to completely uninstall Photoshop. Then... reinstall it again and try ONLY the fontea extension at first. That seems extreme though...
                              • 12. Re: fontea plugin woes
                                As far as i can tell, on a windows x64 bit machine with photoshop cc 2017, the Fontea extension installs in
                                C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Generator\com.madebysource.fontea
                                When i ran the installer, i just used the Install Now button and not Select photoshop manually
                                • 13. Re: fontea plugin woes
                                  When any of you installed Fontea did you immediately run Photoshop after installation ?
                                  • 14. Re: fontea plugin woes
                                    I did. I'd had PS running, quit it, installed Fontea, and immediately ran Photoshop again to test it. Had to log in, and it worked.
                                    • 15. Re: fontea plugin woes
                                      When the installation finished, you were prompted to run Photoshop and so you did.
                                      Re-install the extension, except; do not run Photoshop when prompted.  Rather run Photoshop once the installation is complete.
                                      When the installation is complete and I'm prompted to run Photoshop, I see the fontea extension in Windows > Extension.  Although, if I don't run Photoshop immediately after installation and run Photoshop thereafter the installation is complete; I don't see the fontea extension in the Windows > Extension list ?
                                      • 16. Re: fontea plugin woes
                                        I'm sorry - I wasn't prompted to run Photoshop at all. I did so of my own accord, to see if the installation worked.
                                        From what you're describing, that last sentence appears to me to possibly be an issue with Photoshop, itself. You say it shows up at first, then disappears. Are you running any other extensions? If so, I'd suggest there may be a conflict, and so turning them all off (or removing them from the folder, temporarily) will answer whether there's a conflict. It's possible something else needs to be upgraded.
                                        Not long ago, Photoshop had a limitation on Filters - if you had more than 6 installed, only the first alphabetical 6 would show up. Perhaps one of your other extensions is making Photoshop act in the same way for this issue.
                                        • 17. Re: fontea plugin woes
                                          The limitation could play a role; I'm going to investigate into this.  Thanks for the tip.
                                          • 18. Re: fontea plugin woes
                                            I'm pretty sure it's not the same thing, as an update to Photoshop at the time, resolved the filter issue. However (as I'm not a software engineer) I can logically see where a similar bug might affect extensions, if there's some kind of conflict involved. Good luck on this!
                                            • 19. Re: fontea plugin woes
                                              Where is the location fontea was installed (2017 only) for everyone who posted in this thread ?
                                              • 20. Re: fontea plugin woes
                                                smarquina Level 1
                                                Mine went to the same place as R_Kelly stated (C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Generator) but it does not show up....GRRRRRRRRRRRRRRRRRRRRRRR!!!!!
                                                • 21. Re: fontea plugin woes
                                                  smarquina Exactly; this is what I tried to explain but no one would understand.
                                                  • 22. Re: fontea plugin woes
                                                    shoaibk97559232 Level 1
                                                    I have the same problem I installed it to the both folders.in plug-ins folder as well as in C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions.
                                                    But I got error while applying font to my text layer. I have PS 2018 CC
                                                    • 23. Re: fontea plugin woes
                                                      HOw??? Please elaborate
                                                      • 24. Re: fontea plugin woes
                                                        shoaibk97559232 What error are you getting ? I think you don't need this extension anymore with 2018 let me find out.
                                                        • 25. Re: fontea plugin woes
                                                          I got this error..... Photoshop CC 2018 has not all the google fonts..I need this extension to work for me....but vain in my efforts.
                                                          • 26. Re: fontea plugin woes
                                                            It looks as if the error is related to only one font ?
                                                            • 27. Re: fontea plugin woes
                                                              Nope....when i clicked on each font.. i got this error.....all fonts are faulty.
                                                              • 28. Re: fontea plugin woes
        The top of the page mentions Photoshop 2014/2015 only; It's most likely not compatible with 2017.
        • 29. Re: fontea plugin woes
        cr98673081 Level 1
        Fontea plugin works! Just  make sure that you have selected horizontal/vertical on text box in PS instead of  H/V MASK as this puts a constrain on the fontea fonts. Go to text box as usual, make sure to select Horizontal or Vertical text; write text, click  font of choice on Fontea font box-  Fontea will start downloading the font of your choice. Done!  The mask box was the prob for me.Hope it helps!
        • 30. Re: fontea plugin woes
        Does it still work with Photoshop 2019 ?
        • 31. Re: fontea plugin woes
        ryzanshine Level 1
        I found that it did not.
        I was pulling my hair out over this and finally installed CC 2018 just to check.  I also ran Revo Uninstaller on Fontea in "Moderate" mode to make sure it was removed completely from the registry and any extraneous folders removed.
        I installed Fontea, clicking "Select Photoshop Manually" and chose the Photoshop for CC 2018.  It installed like a charm!
        Then I went into C:/Program Files/Adobe/Adobe Photoshop CC 2018/Plug-ins/Generator/com.madebysource.fontea and copied all those files into C:/Program Files/Adobe/Adobe Photoshop CC 2019/Plug-ins/Generator/com.madebysource.fontea.
        That worked!
