3 Replies Latest reply on Mar 3, 2017 4:44 PM by rob day
    Ink Coverage Error? 299% ink flagged at 300%
    kylamct
      • I have a PSD placed into an InDesign file
      • The PSD was converted to my print profile - ISO coated v2 300 ECI - I also tried with no embedded profile, tried saving as a pdf, all to the same results.
      • The darkest section of the image shows at 299% ink coverage in photoshop
      • InDesign document is also set to ISO coated v2 300 ECI
      • Transparency blend space is set to CMYK, not sure if that matters but everything is consistent.
      • BUT the darkest sections show up red when Ink Coverage preview is turned on in InDesign
      So I tried exporting it to a pdf.
      • PDF output was ALSO set to ISO coated v2 300 ECI
      • The darkest sections show up green BUT they are still listed at 299%! I assure you I was hovering over a green highlighted area when I took this screenshot.
      So apparently the correct color numbers are getting through, but InDesign and Acrobat flag 299% inks at 300%? What gives?
