2 Replies Latest reply on Mar 6, 2017 3:37 PM by Dave LaRonde
    stopped working
    ridwann03
      hi guys i need u help
      i use effect warp stabillazer for few minute is look good dont have problem just few minute again is stopped
      my spec laptop
      AMD A8-7410 R5
      8GB RAM
      Windows 10 64bit
      Image may contain: screen
        • 1. Re: stopped working
          The image you shared doesn't come through where I work. Please try uploading it to the forum directly by dragging your image to the response field or by clicking the add image button above the response field.
          Also, please share more information such as exact version of After Effects you are using (down to the last decimal), format/codec of footage you're using, etc.
          • 2. Re: stopped working
            Dave LaRonde Level 6
            my spec laptop
            AMD A8-7410 R5
            8GB RAM
            Windows 10 64bit
            I will bet that you used up your memory.  You only have 8 GB RAM  to start, and 16 GB is much better.  Warp Stabilizer is intended to stabilize SHOTS and not minute after minute of video.  AE stores the Warp Stabilizer information in the project file, which is put into RAM and it becomes very big.
            In another application, you need to trim your video to the clips you NEED and not the length of all the video you WANT, then export for use in AE.  Do this for each clip you require.
