0 Replies Latest reply on Mar 6, 2017 10:25 AM by Khiali
    ColdFusion 2016 running under J2ee server IBM liberty server Java 1.8 CFCServlet failure
    Khiali
      Hello I am getting the following error when ever i browser to the Mail section in the ColdFusion Admin Portal when I click on
      Application Error
      SRVE0777E: Exception thrown by application class 'coldfusion.bootstrap.ClassloaderHelper.initServletClass:129'
      javax.servlet.ServletException: javax.xml.stream.FactoryConfigurationError: Provider javax.xml.stream.XMLInputFactory could not be instantiated: java.util.ServiceConfigurationError: javax.xml.stream.XMLInputFactory: Provider com.ibm.xml.xlxp2.api.wssec.WSSXMLInputFactory not found
      at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129)
      at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
      at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:332)
      at [internal classes]
      at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
      at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
      at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:207)
      Also when ColdFusion starts I do get the following error on the console
      [err] javax.xml.stream.FactoryConfigurationError: Provider javax.xml.stream.XMLInputFactory could not be instantiated: java.util.ServiceConfigurationError: javax.xml.stream.XMLInputFactory: Provider com.ibm.xml.xlxp2.api.wssec.WSSXMLInputFactory not found
      [err] at javax.xml.stream.XMLInputFactory.newFactory(Unknown Source)
      [err] at javax.xml.stream.XMLInputFactory.newInstance(Unknown Source)
      [err] at org.apache.axiom.om.util.StAXUtils$7.run(StAXUtils.java:504)
      [err] at java.security.AccessController.doPrivileged(AccessController.java:594)
      [err] at org.apache.axiom.om.util.StAXUtils.newXMLInputFactory(StAXUtils.java:494)
      [err] at org.apache.axiom.om.util.StAXUtils.getXMLInputFactory_perClassLoader(StAXUtils.java:565)
      [err] at org.apache.axiom.om.util.StAXUtils.getXMLInputFactory(StAXUtils.java:171)
      [err] at org.apache.axiom.om.util.StAXUtils.getXMLInputFactory(StAXUtils.java:136)
      [err] at org.apache.axiom.om.util.StAXUtils.createXMLStreamReader(StAXUtils.java:223)
      [err] at org.apache.axiom.om.impl.llom.factory.AbstractOMMetaFactory.createXMLStreamReader(Abstrac tOMMetaFactory.java:53)
      [err] at org.apache.axiom.om.impl.llom.factory.AbstractOMMetaFactory.createOMBuilder(AbstractOMMet aFactory.java:95)
      [err] at org.apache.axiom.om.OMXMLBuilderFactory.createOMBuilder(OMXMLBuilderFactory.java:153)
      [err] at org.apache.axiom.om.OMXMLBuilderFactory.createOMBuilder(OMXMLBuilderFactory.java:133)
      [err] at org.apache.axiom.om.OMXMLBuilderFactory.createOMBuilder(OMXMLBuilderFactory.java:104)
      [err] at org.apache.axis2.util.XMLUtils.toOM(XMLUtils.java:590)
      [err] at org.apache.axis2.util.XMLUtils.toOM(XMLUtils.java:575)
      [err] at org.apache.axis2.deployment.DescriptionBuilder.buildOM(DescriptionBuilder.java:97)
      [err] at org.apache.axis2.deployment.AxisConfigBuilder.populateConfig(AxisConfigBuilder.java:90)
      [err] at org.apache.axis2.deployment.DeploymentEngine.populateAxisConfiguration(DeploymentEngine.j ava:857)
      [err] at org.apache.axis2.deployment.WarBasedAxisConfigurator.<init>(WarBasedAxisConfigurator.java :156)
      [err] at org.apache.axis2.transport.http.AxisServlet.initConfigContext(AxisServlet.java:601)
      [err] at org.apache.axis2.transport.http.AxisServlet.init(AxisServlet.java:471)
      [err] at coldfusion.xml.rpc.CFCServlet.init(CFCServlet.java:113)
      [err] at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121)
      [err] at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
      [err] at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:332)
      [err] at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:633)
      [err] at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:475)
      [err] at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:148)
      Any help will be appreciated.
