2 Replies Latest reply on Apr 11, 2017 5:24 PM by Kevin-Monahan
    AE Crash upon open or start of Render Queue
    KLTV8 Level 1
      I have a that I've been working on for months where just recently AE crashes while loading the project. I can import the project and save it and then when I go to render a comp in the render queue, it crashes. The following log is from the latest render queue crash. Once it crashes like this I can't open it again becuase it will simply crash upon opening the project...I have to import the project and re-save under a new name. Thoughts? Any additional info you need? I'm working on a Mac Pro (Late 2013), 3 GHz 8-Core Intel Xeon E5, AMD FirePro D300 2048 MB, 16 GB RAM, 11 GB RAM available for AE.
      Thanks in advance.
      Process:               After Effects [1165]
      Path:                  /Applications/Adobe After Effects CC 2017/Adobe After Effects CC 2017.app/Contents/MacOS/After Effects
      Identifier:            com.adobe.AfterEffects
      Version:               14.0.1 (14.0.1)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           After Effects [1165]
      User ID:               501
      Date/Time:             2017-03-06 14:53:09.626 -0700
      OS Version:            Mac OS X 10.12.3 (16D32)
      Report Version:        12
      Anonymous UUID:        9B196250-04B6-FD4E-5BBA-19C4FAD70432
      Time Awake Since Boot: 4100 seconds
      System Integrity Protection: enabled
      Crashed Thread:        16
      Exception Type:        EXC_BAD_ACCESS (SIGBUS)
      Exception Codes:       KERN_PROTECTION_FAILURE at 0x0000000133d75000
      Exception Note:        EXC_CORPSE_NOTIFY
      Termination Signal:    Bus error: 10
      Termination Reason:    Namespace SIGNAL, Code 0xa
      Terminating Process:   exc handler [0]
      VM Regions Near 0x133d75000:
          VM_ALLOCATE            0000000133c91000-0000000133d75000 [  912K] rw-/rwx SM=PRV
      --> __TEXT                 0000000133d75000-0000000133d7f000 [   40K] r-x/rwx SM=COW  /Applications/Adobe After Effects CC 2017/Adobe After Effects CC 2017.app/Contents/Plug-Ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCo reAudio
          __DATA                 0000000133d7f000-0000000133d80000 [    4K] rw-/rwx SM=COW  /Applications/Adobe After Effects CC 2017/Adobe After Effects CC 2017.app/Contents/Plug-Ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCo reAudio
      Thread 16 Crashed:
      0   com.adobe.ImageRenderer.framework 0x0000000112e8417f (anonymous namespace)::ConvertEndian4444_8u(void const*, void*, int) + 369
      1   com.adobe.ImageRenderer.framework 0x0000000112e8d332 IR::LineConverter::Convert(void const*, void*, int) const + 746
      2   com.adobe.ImageRenderer.framework 0x0000000112df4dd1 void (anonymous namespace)::MultiThreadedComposite::CompositeRows<true, true, true>(int, int) + 401
      3   com.adobe.ImageRenderer.framework 0x0000000112df479d (anonymous namespace)::MultiThreadedComposite::DoComposite(int, int) + 3121
      4   com.adobe.ImageRenderer.framework 0x0000000112df3306 IR_CompositeWithBlendMode + 454
      5   com.adobe.AfterEffects.Glow   0x0000000154104048 RenderComposite(PF_InData*, PF_OutData*, GlowParams*, PF_LayerDef*, PF_LayerDef*) + 584
      6   com.adobe.AfterEffects.Glow   0x000000015410005a EffectMainExtra + 7722
      7   com.adobe.AfterEffects.Glow   0x00000001540ff05d EffectMainExtra + 3629
      8   FLT.dylib                     0x00000001031d6d69 U_GenericPluginDispatch<FLT_PluginDispatch>::Dispatch() + 89
      9   FLT.dylib                     0x00000001031d4595 FLTp_DispatchFilter(short, FLT_FCSpec*, FLT_FCSeqSpec const*, int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*) + 1173
      10  FLT.dylib                     0x00000001031a0077 FLTp_Node::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 583
      11  RG.dylib                       0x000000010439aa38 RGp_NodeInvocation::RenderSingleCheckout(RGp_CheckoutResultImpl*) + 280
      12  RG.dylib                       0x000000010439756e RGp_CheckoutResultImpl::GetWorld() + 126
      13  RG.dylib                       0x00000001043918db RG_CacheNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 1083
      14  RG.dylib                       0x000000010439aa38 RGp_NodeInvocation::RenderSingleCheckout(RGp_CheckoutResultImpl*) + 280
      15  RG.dylib                       0x000000010439756e RGp_CheckoutResultImpl::GetWorld() + 126
      16  RG.dylib                       0x000000010438e7ee RG_CompositeNode::DoRender(RG_RenderRequest const&, RG_CheckoutResult*, M_LRect const&, PF_MaskWorld*, PF_CompositeModePlus const&, RG_CheckoutResult*) const + 158
      17  RG.dylib                       0x000000010438e0a1 RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 481
      18  RG.dylib                       0x000000010439aa38 RGp_NodeInvocation::RenderSingleCheckout(RGp_CheckoutResultImpl*) + 280
      19  RG.dylib                       0x000000010439778e RGp_CheckoutResultImpl::GetOutputWorld() + 126
      20  RG.dylib                       0x000000010438df78 RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 184
      21  RG.dylib                       0x000000010439aa38 RGp_NodeInvocation::RenderSingleCheckout(RGp_CheckoutResultImpl*) + 280
      22  RG.dylib                       0x000000010439b68d RG_Traverser::Execute(RG_RenderRequest const&, M_LRect*, char*, PF_World**, RG_BufferLock**) + 1037
      23  RG.dylib                       0x000000010439b038 RG_Traverser::Execute(RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 136
      24  RG.dylib                       0x000000010439c3be RG_ExecuteGraph(RG_RenderNode const*, RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 622
      25  BEE.dylib                     0x0000000101fcc4e7 BEEp_GenerateAndExecuteCompFrameGraph(BEE_CompItem*, BEE_ItemRenderOptions const&, PF_World*) + 407
      26  BEE.dylib                     0x0000000101fcdac4 BEEp_RenderCompFrame + 196
      27  BEE.dylib                     0x0000000101f7236f BEEp_DrawItemNoCheckout(BEE_Item*, BEE_ItemRenderOptions const&, BEE_RenderTrace const*, BEE_CheckoutReceiptPtr&) + 1215
      28  BEE.dylib                     0x0000000101f6e0a2 BEEp_CheckoutStraightItemBuffer(BEE_Item*, short, short, BEE_ItemRenderOptions const&, BEE_RenderTrace const*, BEE_CheckoutReceiptPtr*, char*, bool) + 7266
      29  BEE.dylib                     0x0000000101f755fb BEEp_CheckoutItemFrame(BEE_Item*, short, short, BEE_ItemRenderOptions const&, BEE_CheckoutReceiptPtr*, char*, bool) + 3099
      30  BEE.dylib                     0x0000000101f74936 BEE_CheckoutItemFrame(BEE_Item*, BEE_ItemRenderOptions const&, BEE_CheckoutReceiptPtr*, bool) + 406
      31  BEE.dylib                     0x0000000101f2a94d BEEp_RenderOutputFrameLock(BEE_CompItem*, BEE_ItemRenderOptions const&, int, int, BM_World**, BEE_RenderCheckoutReceipt*, BM_World***, bool) + 1037
      32  BEE.dylib                     0x0000000101f27612 BEE_RenderMovieAsIs + 4338
      33  BEE.dylib                     0x000000010222857c WorkThread_RenderToOutput(boost::shared_ptr<bee::WorkQueue_Item> const&, boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Params>, boost::function<void (unsigned long long, boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Result>)> const&) + 892
      34  BEE.dylib                     0x00000001022602ad void boost::_bi::bind_t<void, void (*)(boost::shared_ptr<bee::WorkQueue_Item> const&, boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Params>, boost::function<void (unsigned long long, boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Result>)> const&), boost::_bi::list3<boost::arg<1>, boost::_bi::value<boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Params> >, boost::_bi::value<boost::function<void (unsigned long long, boost::shared_ptr<BEE_WorkQueue_RenderToOutput_Result>)> > > >::operator()<boost::shared_ptr<bee::WorkQueue_Item> >(boost::shared_ptr<bee::WorkQueue_Item>&) + 61
      35  BEE.dylib                     0x00000001022476bd boost::function1<void, boost::shared_ptr<bee::WorkQueue_Item> >::operator()(boost::shared_ptr<bee::WorkQueue_Item>) const + 61
      36  BEE.dylib                     0x000000010220ab7a BEEp_WorkQueue_Scheduler_PerformWork(boost::weak_ptr<dvacore::threads::AsyncThreadedExecu tor> const&) + 3258
      37  com.adobe.dvacore.framework   0x00000001059a63da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 218
      38  com.adobe.dvacore.framework   0x00000001059a2d36 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 358
      39  com.adobe.boost_threads.framework 0x00000001086de904 boost::(anonymous namespace)::thread_proxy(void*) + 164
      40  libsystem_pthread.dylib       0x00007fff9c059aab _pthread_body + 180
      41  libsystem_pthread.dylib       0x00007fff9c0599f7 _pthread_start + 286
      42  libsystem_pthread.dylib       0x00007fff9c0591fd thread_start + 13
      Model: MacPro6,1, BootROM MP61.0116.B21, 8 processors, 8-Core Intel Xeon E5, 3 GHz, 16 GB, SMC 2.20f18
      Graphics: AMD FirePro D300, AMD FirePro D300, PCIe, 2048 MB
      Memory Module: DIMM1, 4 GB, DDR3 ECC, 1866 MHz, 0x02FE, 0x45424A3430454738424657422D4A532D4620
      Memory Module: DIMM2, 4 GB, DDR3 ECC, 1866 MHz, 0x02FE, 0x45424A3430454738424657422D4A532D4620
      Memory Module: DIMM3, 4 GB, DDR3 ECC, 1866 MHz, 0x02FE, 0x45424A3430454738424657422D4A532D4620
      Memory Module: DIMM4, 4 GB, DDR3 ECC, 1866 MHz, 0x02FE, 0x45424A3430454738424657422D4A532D4620
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.21.171.68.1a5)
      Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Thunderbolt Ethernet Slot 0-1, Port 2, Ethernet, en9
      Network Service: Ethernet 1, Ethernet, en0
      PCI Card: AMD FirePro D300, Display Controller, Slot-1
      PCI Card: AMD FirePro D300, Display Controller, Slot-2
      PCI Card: pci105a,8760, RAID Controller, Thunderbolt@79,0,0
      PCI Card: Focusrite Clarett, Thunderbolt@183,0,0
      PCI Card: pci105a,8760, RAID Controller, Thunderbolt@104,0,0
      PCI Card: ethernet, Ethernet Controller, Thunderbolt@159,0,0
      PCI Card: ethernet, Ethernet Controller, Thunderbolt@159,0,1
      PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@231,0,0
      PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@230,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@229,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@229,0,1
      PCI Card: pci1b4b,9182, AHCI Controller, Thunderbolt@107,0,0
      PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@229,0,2
      PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@236,0,0
      PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@235,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@239,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@239,0,1
      PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@239,0,2
      Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
      USB Device: USB 2.0 Bus
      USB Device: Hub
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: Hub
      USB Device: MT1887
      USB Device: FaceTime HD Camera (Display)
      USB Device: Apple Thunderbolt Display
      USB Device: Display Audio
      USB Device: Hub
      USB Device: Keyboard Hub
      USB Device: Apple Keyboard
      USB Device: USB 3.0 Bus
      USB Device: micro P2 drive
      USB Device: USB3.0 CF SD
      USB Device: USB3.0 Hub
      USB Device: USB2.0 Hub
      USB Device: PTZ-631W
      FireWire Device: #1, MATSHITA AJ-PCD20, Up to 800 Mb/sec
      Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
      Thunderbolt Device: Pegasus2-R, Promise Technology, Inc., 1, 19.2
      Thunderbolt Device: SANLink2 10GBase-T, Promise Technology, Inc., 3, 24.2
      Thunderbolt Device: Clarett2Pre, Focusrite, 1, 7.1
      Thunderbolt Device: Thunderbolt Display, Apple Inc., 3, 26.2
