Good Day!
I almost follow the all instructions to save the results in server. But it cannot generate results in quiz analyzer.
Can anyone help me. [gallery ids="11573,11574,11572"]
Don't forget to restart Apache.
Oliver,
Create a folder in your webroot or htdocs folder (if you’re using wamp/xampp).
For example,
http://localhost:8012/report/internalserverread.php
http://localhost:8012/report/internalServerReporting.php
I think this should work. You will also see the CaptivateResult folder.
Saurav
Sir Saurav,
I'm using Xampp.
How can i create a folder in webroot? Because my webroot is in "Templates/Publish"
Oliver
Create a folder report in C:\xampp\htdocs\report.
Copy both the php files in the report folder.
Still have an error Sir, I almost follow your instruction.
Oliver,
Since you have XAMPP, can you let me know on which port Apache is running at?
Saurav
Can you change your webrooot to /xampp/htdocs
okay sir, after i change the documentroot in Htdocs folder i will copy the whole Templates folder? or only the internalServerReporting.php and internalserverread.php?
After you change the document root, create a folder report and then copy only the two php files in xampp/htdocs/report.
then try to access the using localhost:8080/report/internalServerReporting.php
Thank you so much Sir! It can generate the results now in the Quiz analyzer.
But the CaptivateResult is still not visible in the Templates/Publish folder.
The CaptivateResult folder will be in the path xampp/htdocs/report.
Sir I find the CaptivateResult folder. Thank you so much!!
Glad everything's working now. Let us know if there's any problem when generating the scores.
Saurav
Yes Sir, Thanks a lot!
Regards,
Oliver
