Hi there!
Is it possible to search my InDesign text for all those ff-ligatures which are connecting two syllables of a given word?
Example:
an ff-ligature in »offensive« should be found, another one in »offspring« not
Thanks a lot!
Simple enough, if your syllables are easy to count. This will work for a, e, i, o, u in CS6 and all CC flavors:
[aeiou]\Kff(?=a|e|i|o|u)
If you expect to encounter any other character of a certain glyph set in your doc, you may need to use pattern [=a=] instead of a plain a, and so on.
This is a GREP string, right? Works like a dream, though I have no idea why
Thanks a big big lot!
winterm,
very nice your grep.
i had a similar problem and made a list of words with a different method (eliminating those without ff) but was bizarre.
I used your grep but it marked just the ligature.
How can I adapt it to search for all those words with any ligature?
thanks
As you know, ligatures depend entirely on the font you’re using. AFAIK, GREP knows nothing about it, so you can't search for 'ligatures' as such, just for certain combinations: ff, fi, ffi, ffl, fl, fj, whatever else.
Here’s the one which finds words containing ff:
\w*ff\w*
and a bit more inclusive version (allows dashes, apostrophes...):
\S*ff\S*
Barb,
Thanks. It is clean, short and straight.
Best regards.
Looks like I simply have to learn to use that GREP thing. Any recommendation for starting that, book, website, mystic herbs?
i've been using Peter Kahrel's overview:
GREP in InDesign - O'Reilly Media
plus i've found Jongware's 'What the GREP' script very useful:
since as well as pointing out errors, it'll list what a grep is literally doing in words.
