3 Replies Latest reply on Mar 9, 2017 11:31 AM by BarbBinder
    Objects changing size during placing if mouse is moving.
    damond76037267 Level 1
      When placing an object using control D (or place from the file menu) if the mouse is not held perfectly still Indesign creates a new bounding box for the object and places it in that box scaled to fit. The net effect being that if I am trying to place a business card sized PDF into Indesign and don't have the mouse perfectly still when I left click the art drops in at a very small size (however much the cursor moved while dropping) and I have to undo and redo this action.
      Not the end of the world but really annoying working in pre-press and placing hundreds of object onto grids on a daily basis. Is there a way to shut this feature off? Usual google search and perusal of Adobe forums is yielding no results.
      Damon
        • 1. Re: Objects changing size during placing if mouse is moving.
          BarbBinder Adobe Community Professional
          InDesign thinks you are holding down the mouse and dragging out a frame, which is a feature.
          It sounds like an issue with your mouse: is it a new mouse? is the driver up to date? is it an apple magic mouse?
          • 2. Re: Objects changing size during placing if mouse is moving.
            No, It is the same mouse I've been using for two and a half years. Running a windows 7 machine so no, not a magic mouse. Device manager scanned for new drivers and found it was up to date.
            We recently upgraded from CS3 to Cloud, which is when it started happening. As I suspected it is an added feature, I was hoping there was a way to toggle it off is all.
            It overrides the crop to settings under Show Import Options, kinda defeating the purpose of having that option.
            I do a lot of placing and I do it very fast, it would make my life easier if this could be turned off. I take it since you represent Adobe as far as you know it cannot be turned off?
            Damon
            • 3. Re: Objects changing size during placing if mouse is moving.
              No, I don't represent Adobe. This is a user-to-user forum, and I'm a user like you. I can tell you that I have used (and taught) every version of InDesign and have never observed this behavior of dragging out a small graphics frame when you intend to click. That't why I'm suspecting the mouse. What if you change ports? Try a difference mouse?
              What cloud version are you on? Is it CC 2017? Is Service Pack 1 installed for Win7?
