7 Replies Latest reply on Mar 9, 2017 5:59 AM by Deaf Mike
    Fly by images fuzzy I thought they wouldn't be?
    Deaf Mike Level 1
      I'm doing one of those fly by effects where you have a bunch of scattered photos laying around and then you take the camera and fly it around - not physically but in AE.
      I created an image of 3840x1440, scattered the photos around and then imported it into a 1280x720 comp.
      Everything is going great except when I try to zoom into one photo so it's full frame.  The photo is not crystal clear but pixelly, almost as if I zoomed into it at 200% in PSD showing the pixelliness of it.  I thought because I was zooming in with the camera that it would be like a true fly by and be clear as cam flies by.
      These are great photos by the way - all I did was copy them into my 3840x1440 then scaled them down to fit into my scattered layout.
      Maybe I'm just assuming too much but I have seen photos fly by on TV (looks like it was made it AE) and they look better than mine. Should I have made my scattered photos graphic 150 or 300 DPI - would that help?
      Any help is appreciated.
        • 1. Re: Fly by images fuzzy I thought they wouldn't be?
          Kyle Hamrick Adobe Community Professional
          To clarify, are the photos inside precomps at all, or just placed as-is into one main 720 comp? Having them in precomps is one of the easiest places to get tangled up on this.
          Dummy questions - have your resolution set correctly? In both viewer and preview panel? Accidentally turn on draft quality? Accidentally set the photos to draft quality?
          • 2. Re: Fly by images fuzzy I thought they wouldn't be?
            imeilfx Adobe Community Professional
            And one other thing. Did you make your composition 3840x1440 as a precomposition where you put all your photos and then that precomp in your main composition 720P/1080p and from there you are zooming in on them using camera. Or your're in one big 3840x1440 composition and zooming in on your photos. If second part is correct that could be the problem because you are actually zooming in those smaller pictures in bigger 3840x1440 resolution.
            • 3. Re: Fly by images fuzzy I thought they wouldn't be?
              You cannot scale down images and then hope they retain full res. You need to keep them at full or use continuous rasterization/ collapse transformations more consequently even in the pre-comps, though that may have sideeffects on your 3D flight. There's nothing wrong here, you are simply messing with the render and transformation order, which you need to understand.
              Mylenium
              • 4. Re: Fly by images fuzzy I thought they wouldn't be?
                Deaf Mike Level 1
                Thanks all for your help.  To answer your questions, the 3840x1440 file was made in Photoshop and all of the photos are lined like one huge tiled display.  I cannot post it here because it has confidential photos.
                I then brought this into the comp with settings of 1280x720.
                When the camera flies on the X and Y planes, it works perfectly, as the various pictures slowly fly by like I wanted them to.  I just cannot zoom into one of the photos to make it full frame (1280x720).  I thought because it was a camera that it would zoom in and keep the integrity of the photo because after all, if the camera is 3D, well, I thought everything would look fine.
                One question - if I made that 3840x1440 file at a resolution 150 or 300 instead of 72, and then zoomed in with the camera on THAT file, would the photo be clear because it's of a higher resolution?  I don't want to have to re-do the entire file like this only to find that that won't work neither.  Thanks.
                • 5. Re: Fly by images fuzzy I thought they wouldn't be?
                  Ok. So:
                  - check how many photos you have on your 3840x1440 - i mean. If you need to zoom in to any photo -to be sure that you have full resolution of it - your photo on that canvas have to have as many pixels as youtr main composition (or more). If you have smaller pictures - as Myllenium said - you will have lower quality because by zooming in you are enlarging it.
                  - or maby...  - did you turn on DoF (Depth of Field for your camera? If so - you have to turn it on or set your Focus distanse to your surface/photo
                  And dpi does not change anything for video. Pixel resolution is what you have to look at.
                  • 6. Re: Fly by images fuzzy I thought they wouldn't be?
                    Pixels are pixels and video doesn't have DPI. You really need to work with the full resolution images. Depending on what you actually do, it may be sufficient to place the "hero" image at full res in the same spot and perhaps one row surrounding it and then do some sneaky cross-fade at some point as you dolly in, but otherwise - what's not there is not there. You have to go back to the original sources, even if working with so many high-res images in AE can be a pain.
                    Mylenium
                    • 7. Re: Fly by images fuzzy I thought they wouldn't be?
                      Deaf Mike Level 1
                      This is a lesson learned and thanks for all of your help.  The X-Y works great and I know now how to use Z for something like this.
