• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to search the contents of text frame anchored to the current story
Explorer ,
Mar 08, 2017 Mar 08, 2017
I have a multipage story with many anchored text frames. I'm trying to find a way to search the contents of all the anchored objects on my current page. I've only been able to do it by selecting all text frame objects on the current page and then search them. However, this include other text frames that may have a match I don't want.
However I'm not sure how this is even working as when I run
alert(app.activeWindow.activePage.pageItems.length)
the number of items returned is all the text frames on the page except the anchored ones.. in this case, 6 instead of 21.
Any ideas you have are appreciated!
Thanks!
Christopher
TOPICS
Scripting
Views
2.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guru ,
Grep with "~a"
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 09, 2017 Mar 09, 2017
Thanks, that will find the anchor point in the main story, but how can I get to the contents of the anchored text frame?
Votes
Translate
Translate
Report
Report
Guru ,
You can actually us find text and use "^a"
The use find = myFinds.textFrames[0] then contents = find.isValid && find.contents
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Christopher,
if you want a search through formatted text of all anchored text frames of your main story, you could build an array of formatted text objects and search this with GREP or TEXT Find/Replace like that:
1. Select some text or a text frame of your main story
2. Loop through the parentStory.textFrames.everyItem().texts.everyItem().getElements() array.
3. Now you could do a GREP or TEXT Find/Replace action on every instance found.
var sel = app.selection[0];
var mainStory = sel.parentStory;
var fomattedTextsOfAnchoredFrames = mainStory.textFrames.everyItem().texts.everyItem().getElements();
for(var n=0;n<fomattedTextsOfAnchoredFrames.length;n++)
doSomethingWithFormatted(fomattedTextsOfAnchoredFrames);
// Build a function that will do something with the formatted text of a text frame
function doSomethingWithFormatted(text)
// Do something reasonable here:
// … A GREP Find/Replace action perhaps …
// Not very reasonable, but maybe enlightening.
// Write the contents of the anchored text frames to the JavaScript Console of the ESTK
$.writeln(text.contents)
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Guru ,
Hi Uwe,
Nice one,
That's normally going to be a better approach than using the Grep.
If one doesn't need to loop through the individual frames one could just do find / change on the whole collection.
var fomattedTextsOfAnchoredFrames = mainStory.textFrames.everyItem().texts.everyItem();
fomattedTextsOfAnchoredFrames.fillColor = app.activeDocument.swatches[5];
app.findTextPreferences.findWhat = 'd';
app.changeTextPreferences.changeTo = 'D';
fomattedTextsOfAnchoredFrames.changeText();
Regards
Trevor
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Uwe & Trevor,
Why mention the "main" story"?
Is this not enough?
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = "~a";
myFound = myDoc.findGrep();
var F = myFound.length;
for ( var f = 0; f < F; f++ ) if ( myFound.textFrames[0].isValid ) {
    // Do something!
    app.findChangeTextOptions.includeMasterPages = false;
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Obi-wan,
you would find perhaps too much. The scope with your code is the whole document.
You'll find also anchored objects with other stories that are not part of the "main story".
Regards,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
… So, how define the "main" story?
Votes
Translate
Translate
Report
Report
Community Expert ,
Only Christopher could answer that.
We cannot see in his document…
After re-reading his first post, I'm not sure if there is only one main story.
Or if there are some threaded text frames going to other pages where he only is interested in the text frame(s) of one page.
Before doing any other suggestions we should hear from him how his page is structured.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks!
There are 6 text frames on the page, I'm only interested in one of them, which has the anchored text frames.
Only the main frame I'm interested in is threaded text to other pages, but I only want to search the anchored objects on the current page
Thanks!
Christopher
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks!
myFound = myFrame.findGrep();
    // Do something!
    //app.findChangeTextOptions.includeMasterPages = false;
    //app.findGrepPreferences = app.changeGrepPreferences = null;
alert(myFound.textFrames[0].contents)
Works perfectly for what I was trying to do. All the frames on the page have a variable name. The script is building a book from rtf files and doing the page layout and design one page at a time.
However, for curiosity
How would you search for a string in the anchored frames or a character style?
For example, if I was searching for the string "I love indesign scripting" with character style "javascript_is_best" in one of the anchored frames to "myFrame"?
Votes
Translate
Translate
Report
Report
Explorer ,
Got it! Maybe there is a cooler way but this works! I guess that is what some of you were trying to point out in the beginning...
app.findGrepPreferences.findWhat = "I love indesign scripting";
app.findGrepPreferences.appliedCharacterStyle = myDoc.characterStyles.item("javascript_is_best")
founds2 = myFound.textFrames[0].findGrep()
// I only care about the first one.. the others can wait
if(founds2[0]){alert(founds2[0].contents)}
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Hi Christopher,
no. If you are looking at your code, you are not there.
You are writing:
1. multipage story
2. many anchored text frames
You want to know:
1. anchored objects
2. Current page
Your code is:
That would also find anchored frames not on the current page.
It would even find anchored objects on the pasteboard. Or on master spreads.
app.documents[0].layoutWindows[0].activePage.findGrep();
is no option. findGrep() is a property of: app, cell, character, column, document, insertionPoint, line, paragraph, row, story, table, text, textColumn, textFrame, textPath, textStyleRange, word, XMLElement, XmlStory
We have to look into a different method to identify all anchored text frames in your story on the current page.
I don't know how you identify your multipage story.
Obi-wan is asking this as well.
Let's assume you have identified it somehow.
You first have to find out what text containers of your story are on the current page.
The snippet below is not my favorite. It only works best if we do some assumptions. It would fail if you e.g. anchored groups with text frames.
And it assumes that all anchored text frames on the "current" page belong to your story you are interested in.
But it will find the anchored text frames on your current page only.
var currentPage = myDoc.layoutWindows[0].activePage;
    if
        // We are interested in text frames only.
        // Not anchored graphic frames etc.pp.
        myFound.textFrames[0].isValid &&
        // Is not on the pasteboard:
        myFound.textFrames[0].parentPage != null &&
        // Belongs to the "current" page; I assume you mean the activePage :
        myFound.textFrames[0].parentPage.documentOffset == currentPage.documentOffset
        $.writeln(f+"\t"+myFound.textFrames[0].contents);
Also test:
// vs.
$.writeln(f+"\t"+myFound.textFrames[0].parentStory.texts[0].contents);
if one of the text frames is in overset.
Not provided: text in tables, nested tables, footnotes, notes.
Regards,
Uwe
// EDITED: Somehow the forum software messed up my formatting
// Hope, this is correct now.
Votes
Translate
Translate
Report
Report
Community Expert ,
Trevor×…  wrote
… If one doesn't need to loop through the individual frames one could just do find / change on the whole collection. …
Hi Trevor,
yes. But all depends on the structure of the anchored frames.
That could be imply deeper nested text frames or tables etc.pp.
If there are only text frames anchored and no text path objects my idea will work.
If there are groups anchored with text frames inside we need a different approach to gather all formatted text.
Also if one wants text in table cells where the table is placed in anchored frames…
One could also start with:
app.selection[0].parentStory.allPageItems;
and do a little sorting. Extracting tables with a TEXT search after <0016> getting to texts of the cells.
And finally get a flat array of text objects by concatenating every texts to a result array.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
