• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
after effect 2017.1 wont open
New Here ,
Mar 09, 2017 Mar 09, 2017
hi.
my after effect 2017.1 wont open and just shows an empty box.i tried the way you already told in other question(change the Adobe to OldAdobe )but it didnt worked!
i have problem since i updated the AF from 2017 to 2017.1.
and my system is windows 10 home single language.
Views
926
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ ,
Mar 24, 2017 Mar 24, 2017
Check to see if there are instances of AE running in the task manager if so kill them, reboot your system and see if things are better.
If not you should probably contact support.  They will at least be able to help you figure out what information you need to provide like AE logs, Adobe logs & system event logs,
~Gutterfish
Votes
Translate
Translate
Report
Report
Enthusiast ,
I concur with Gutter, though the symptom of the blank box, I've not seen.
Usually, if there are two or more (actually one running and you trying to launch one) instances running in task manager, it simply will not launch.  In that case, task manager, kill them, and it usually works (even without a reboot), though a reboot often helps and will certainly kill all the instances.
Eric
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Apr 14, 2017 Apr 14, 2017
Hi Iman,
Did you ever get After Effects to launch? Did the advice here assist you? Please let us know if you still need help with that.
Kevin
Votes
Translate
Translate
Report
Report
LEGEND ,
Apr 19, 2017 Apr 19, 2017
LATEST
Today's update should fix this issue.
Votes
Translate
Translate
Report
Report
