When you go back to your radial filters, is there away to cycle thru them? I've created several, and the center of each is outside the image area, so the grey center box doesn't show.
mike240's answer on this page had the solution. I'd never figured out how to make the image smaller till now! I can see the radial filters I've applied now that have centers outside the image itself. Great!
Not that I'm aware of. You can hit the TAB key to close the side panels, select the Radial Filter pin, hover the mouse point over the hidden right side panel, which will allow adjusting the settings. Repeat for other pins and then hit the TAB key to restore the side panels.
Thanks so much. Did not know I could view photos at these smaller sizes!
If I have understood your problem correctly, you might find this short video helpful....
Lightroom Coffee Break: Viewing with Negative Magnification - YouTube
