2 Replies Latest reply on Mar 10, 2017 5:56 AM by Bahaar Khan
    Issue with layers when colouring line art - help?
    eloisegreen
      Hi everyone,
      Right I'm going to try and be as clear as possible in my explanations, bearing in mind I'm fairly new to photoshop.
      I'm colouring in line art that I made in Illustrator, in Photoshop. I copied one drawing into Photoshop as a smart object and then using a group and a layer mask, applied colour. That worked fine.
      Then I copied in another drawing into the same document as a smart object (creating some sort of montage), selected the drawing, made a group and layer mask all fine, then when I started applying colour in a new layer - NOTHING HAPPENED. This is so frustrating, my brush is touching down and everything, no error message but there is no colour, no effect whatsoever. I'm basically painting with invisible ink and I don't understand what I'm doing wrong.
      I've checked, and there were no other selections active aside from the layer I wanted to lay colour on so I don't think that's the issue.
      Is it not possible to colour in several different objects using this technique in the same document? Do I need to have all the objects imported as a smart object at the same time?
      Thanks in advance!
      All the best
