11 Replies Latest reply on Mar 20, 2017 11:37 PM by gnanaprakashmarimuthu
    Windows apk not built
    grega29105989
      Please I have been trying have since two weeks to figure out what is the problem with these statement from the build log of windows and i just can't find where the problem is. The bold test i think is my problem but i just can't find what to do in my folder. Below is the log
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-statusbar@~2.1.3" via npm
      Installing "cordova-plugin-statusbar" at "2.1.3" for windows
      "plugman.cmd install --platform windows --project /cygwin/tmp/gimlet/2511632/project --plugin phonegap-plugin-push@~1.8.0 --var SENDER_ID=XXXXXXX": Fetching plugin "phonegap-plugin-push@~1.8.0" via npm
      Installing "phonegap-plugin-push" at "1.8.4" for windows
      Updating appxmanifests with ToastCapable=true...
      Failed to install 'phonegap-plugin-push':Error: Cannot find module 'C:\cygwin\tmp\gimlet\2511632\project\platforms\windows\cordova\lib\AppxManifest'
        at Function.Module._resolveFilename (module.js:337:15)
        at Function.Module._load (module.js:287:25)
        at Module.require (module.js:366:17)
        at require (module.js:385:17)
        at module.exports (C:\cygwin\tmp\gimlet\2511632\project\cordova\plugins\phonegap-plugin-push\hooks\windows\ setToastCapable.js:5:24)
        at runScriptViaModuleLoader (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cor dova-lib\src\hooks\HooksRunner.js:187:18)
        at runScript (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cor dova-lib\src\hooks\HooksRunner.js:165:16)
        at C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\pgb-cord ova-lib\src\hooks\HooksRunner.js:133:20
        at _fulfilled (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\q\q.js: 787:54)
        at self.promiseDispatch.done (C:\Users\Administrator\AppData\Roaming\npm\node_modules\pgb-plugman\node_modules\q\q.js: 816:30)
      Please i will appreciate your help.
