Hi everyone, Is there any way of having a different favicon on different pages on the same website? For example on all the files in a certain subfolder. I have a website which hosts multiple unrelated projects (each in it’s own subfolder) and it would be good if each could have it’s own favicon.
The code below would put a favicon (in the root folder) on every page on the website, but could you put a favicon in a specific subfolder and direct the browser to use that for all the files within that particular subfolder?
<LINK REL="SHORTCUT ICON" HREF="http://www.gwilliams-designs.co.uk/favicon.ico">
The code below puts a favicon from within the same folder on any page which has this code, so I could just put that on every single file in the folder but the problem with that is if I then ever a have a dedicated website and url just for that project in the future, would I have to go and remove it of every single file to make the main code (above) work?
<LINK REL="SHORTCUT ICON" HREF=".\favicon.ico">
I would be grateful for any advice. Thanks for your help,
You can set it on a per page basis
<link href="myfavicon.ico" rel="icon">
I read the info on the link but I’m afraid it’s all double dutch to me. I’m not up on coding and the terminology that goes with it and practically every sentence lost me. What I do know from trying that code is that it only works on files that are in the same folder as the favicon. When you have files in yet another subfolder, that code does not work. I presume some sort of modification must be made to direct it to the right folder containing the desired .ico
This is the case also for the <LINK REL="SHORTCUT ICON" HREF=".\favicon.ico"> code which as far as I can tell achieves exactly the same thing! It only works on the files in the same folder and not on files in yet another subfolder.
As a Dutchman, I am very comfortable with the language.
Ha! Ha! or should I have said “it's all greek to me?” ironically, the website the icons are for is a portuguese audio exercises website!! - Skeleton_Portuguese
Anyway, I think I've figured it out now using either of the codes but adding ../ to the files that are in subfolders of the folder. e.g …
<LINK REL="SHORTCUT ICON" HREF=“../favicon.ico">
This seems to be working on my local site but I haven't uploaded the new files with this code to the remote server yet. Thanks again for your help.
I think that you should also have a look at How to Add a Favicon to your Site - QA @ W3C
Thanks Ben, I will look at that link shortly, just before I try out your code I just need to ask a few questions …
To use that code does your favicon have to be named “myfavicon.ico” rather than just “favicon.co”?
If a file is in yet another folder within the subfolder, I assume you have to make some sort of modification to the code for those files as they are not in the same folder as the favicon? Is that the case and if so what?
When using that code am I right to assume that the favicon goes in the appropriate subfolder not the root folder?
Anyway. I will read that link now, thanks again.
Can be any name like junk.ico
Can be in any location, similar to a normal image
As long as the link points to the correct icon.
Having said that, I think you should experiment with using a PNG rather than ICO. Also, if there is no link in your document, the browser will default to favicon.ico
