1 Reply Latest reply on Mar 13, 2017 10:39 AM by Akki_24
    Changing Pen thickness in Acrobat on iPad Pro
    toddleo
      Is there a way to change the thickness and other properties of the PEN tool in Acrobat using iPad Pro w/ pen?  I cannot seem to bring up any sort of menu or adjustments for this.
        • 1. Re: Changing Pen thickness in Acrobat on iPad Pro
          Akki_24 Adobe Employee
          Hi Toddleo,
          I assume you are referring to the thickness of the Drawing Tool in Adobe Acrobat Reader mobile application?
          Yes, you can change the thickness of the tool.
          1-
          2- Once you have saved, just tap on the drawing that you have done.
          3- Options will come up as Delete> Thickness> Color> Opacity
          4- Select Thickness > (0.5pt, 1pt, 3pt, 5pt, 7pt, 9pt, 11,pt)> Save
          5- The particular thickness will be set as default.
          Regards,
          Akanchha
