• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Duplicate links not collapsing into 1 group
Community Beginner ,
Mar 10, 2017 Mar 10, 2017
I have been having issues with collaborations in InDesign. When I drop a duplicate item into InDesign that another team member has already put in the file it shows as a different file under the links menu. For example:
User A(Me) - drops a pdf into the document
User B - drops the same pdf into the document and it shows as a different file
User C - drops the same pdf into the document and it combines with User B's file
The same also happens when going in a different order:
User B - drops in pdf
User A - drops in same pdf and it shows as a different file
User C - drops in the same pdf into the document and it combines with User B's file
As you can see in the above image, the file I inserted is different from the files that User B and C put into the file.
If I place in another of the same file it groups with my first one creating 2 groups of 2 files that are the same.
We are all:
On the same network
Working in the same shared drive
Running the same OS (macOS Sierra 10.12.3)
On the same computers (imac 27-inch, Late 2013) with the same specs
Running the same version of InDesign (2017.0 CC release Build 12.0.0.81)
Views
682
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Mar 13, 2017 Mar 13, 2017
After expanding the view to show the folder by folder section I was able to see that in folder 6 on their computers the shared drive was lowercase but not my own. I reconnected and remapped the shared drive to my login items so that it shows up as a lowercase and no longer see this happening.
Votes
Translate
Translate
Guide ,
I've never worked the way your team is working, so please forgive me if this is a dumb question, but what do you mean by:
Are you placing a PDF onto an InDesign page (and if so, is it via the menu, or drag-&-drop)?
Where is the PDF (on a local drive, a network)?
Does this have something to do with packaging?
Votes
Translate
Translate
Report
Report
Drag and drop. Both pdf and document are saved on the same network share.
Votes
Translate
Translate
Report
Report
Guide ,
And you're sure you don't have two copies of this PDF? If you drag and drop (or File>Place) from two copies from the same location, they will show up like the top item in your screen shot (with the (2) next to the name, showing you have two of the same link). If you drag a third one that's a copy from a different location, it won't be (3) together, it will be like you have in the screen shot. Try selecting each and using Reveal in Finder from the flyout and see if they go to the same image.
Votes
Translate
Translate
Report
Report
It's the same file. I know this because we were doing testing where the InDesign file and pdf were the only items in the folder. Here is the full image that was chopped off in the description. (Hopefully it scales correctly)
Votes
Translate
Translate
Report
Report
Guide ,
This latest screen shot only shows two items, so I can't tell without the third.
Votes
Translate
Translate
Report
Report
LATEST
Votes
Translate
Translate
Report
Report
