1 Reply Latest reply on Aug 25, 2008 5:34 AM by robdillon
    Percent Loaded
    ßryD
      Greetings
      Tried this lingo, won't work.
      on startMovie me
      member("Intro").member.preLoad()
      go to frame 1
      end
      at frame 1
      on exitFrame me
      if member("Intro").Loaded < 100 then
      go to the frame
      else
      go to frame 2
      end if
      end
      I also tried
      on exitFrame me
      member("Intro").member.stream
      if member("Intro").member.percentStreamed < 100 then
      go to the frame
      else
      go to frame 2
      end if
      end
      also didn't work
      Hope that someone can help
        • 1. Re: Percent Loaded
          robdillon Most Valuable Participant
          For your startmovie function, you want to use preloadMember:
          preloadMember member "intro"
          This command will begin the process of loading the member into memory. It will not stop the playback head or do anything else while the loading takes place. If you want to monitor the loading process, you can test for the loaded of member. This property is a boolean, so it reports back either true or false, not the amount of the member that has been loaded so far.
          The percentStreamed property can be used to monitor the amount of the file that has been streamed from the server. This property only applies to SWA, Flash or Quicktime files.
