1 Reply Latest reply on Aug 24, 2008 8:01 AM by robdillon
    Buttons do not work correctly
      I am not sure if I should have posted this mesage here; hope you can help. Thank you
      Hi, I've created a Nav_menu movie in my library (insert it into my main Scene). Inside my Nav _menu I have a layer called "Action" and I have the following code for each of my buttons. But for some reason they don' work correctly. What is suppose to happen when you click the button is a short animation that basically brings up a window, but then I'd like to add some text (after the short animation finishes). But it doesn't work.
        • 1. Re: Buttons do not work correctly
          robdillon Most Valuable Participant
          For each button, you have a gotoAndStop() and a gotoAndPlay() or you have two gotoAndStop() functions. These are all directed at the main timeline. If you want to have a particular movieclip animate then you have to tell that clip to respond. If one of these clips has an instance name of Action, then use Action.gotoAndStop(1); for instance.
