0 Replies Latest reply on Oct 2, 2008 2:30 AM by _F_L_E_X_E_R_
    mxmlc: Error: Problem finding external Model
    _F_L_E_X_E_R_
      I am currently trying to compile a flex project with the mxmlc compiler. Unfortunately I always get this error message:
      Error: Problem finding external Model: config.xml
      It seems as if this resource cannot be found by the compiler. All source-paths and libs are are set as in the .actionScriptProperties file. Other resources such as style sheets can be found without any problem.
      Furthermore, when I write the xml model inline or if I provide the relative path inline the compiler understands that and does not show the error.
      <mx:Model id="config" source="config.xml"/> => does not work
      <mx:Model id="config" source="../config/config.xml"/> => works
      What can I do to tell the parser where the config.xml file is located?
