2 Replies Latest reply on Mar 13, 2017 7:07 AM by chopsuey
    Options selection.
    chopsuey Level 1
      (Sorry for my English)
      Hello, I would like to know if it is possible to modify the selection options when I recuperate a selection with for example the selection mask or by ctrl+clic on the layer.
      With the "lasso" I can have a progressive contour or a smoothing.
      I would not have smoothing when I use a selection mask.
      Thank you.
        • 1. Re: Options selection.
          Recuperate a selection... You can make selection better many ways in Photoshop. Photoshop menu select has options to modify selection and transforms selection.  There refine mask, select and mask. add a selection to a layer as a layer mask the use Photoshop filters on that layer mask.  Apply Image..., Calculations...,  Save a selection as an Alpha channel work on the channel with Photoshop tool.  You can always make a selection better you just need to be a good Doctor. On top of that if you are good artiest Photoshop paint brush in your hands with you  brushes and blend modes you may revive the dead.
          • 2. Re: Options selection.
            chopsuey Level 1
            Ok Thank you
