3 Replies Latest reply: Aug 25, 2008 7:42 AM by msalome RSS
    Exporting to FLV
    msalome Community Member
      Any reason flv would not be an option when I try to export? Is there something I need to do to my .fla before this option becomes available? I can export as .swf, quicktime, animated gif, pict sequence, and several other kinds of image sequences.
      I thought there might be a problem with the way my software was installed at work (Windows) so I downloaded a trial copy at home (Mac) and am having the same problem with the same .fla.
        • 1. Exporting to FLV
          Noelbaland Community Member
          You can't export timeline animation in Flash as an FLV file. It's a video only option and becomes available when you import a video file into Flash.
          You can export animation as a Quicktime file, re-import it back into Flash, and then export as an FLV
          • 2. Re: Exporting to FLV
            Newsgroup_User Community Member
            > sequences.
            There is no export to FLV. You need to produce some other video format then you
            can convert it to FLV using the Encoder or Import Video option.
            Best Regards
            Urami
            "Never play Leap-Frog with a Unicorn."
            <urami>
            If you want to mail me - DO NOT LAUGH AT MY ADDRESS
            </urami>
            • 3. Re: Exporting to FLV
              Thank you both!!
