9 Replies Latest reply on Mar 15, 2017 7:00 AM by Kalow
    Prevent drop shadow from showing on transparent pixels
    Kalow
      On the attached example - how can I prevent the drop shadows from casting on transparent pixels?
      Each fish is a smart object with a drop shadow effect that could quickly be replaced with a banana, bowling-pin, etc. I want the shadows on each of the smart objects behind, and the inside and flaps of the box.
      Toggling the "lock transparent pixels" option in the layers panel doesn't seem to apply to effects.
      I've been working on a solution for a while and can't find anything that seems right. Any help is appreciated! Thanks.
        • 1. Re: Prevent drop shadow from showing on transparent pixels
          SJRiegel Adobe Community Professional & MVP
          Make a group of all your layers.
          Turn off all of your shadow effects.
          Use the magic wand or quick select tool to select the transparent area, then add a mask of it to your group.
          When you turn the shadows back on, they should be only on your non-transparnet areas.
          • 2. Re: Prevent drop shadow from showing on transparent pixels
            Kalow Level 1
            Thank you - I've tried that in the past and it does work, but is kind of clumsy and time consuming.
            This requires turning shadow effects on-and-off for 30-40 objects sometimes (can't find a way to turn them all off with one click) and repeat each time I replace the contents of the smart object.
            Any other ideas?
            • 3. Re: Prevent drop shadow from showing on transparent pixels
              Trevor.Dennis Adobe Community Professional (Moderator)
              Your problem, of course, is that you need the shadows to overlap the other box contents 'inside' the box, so I can't think of any significant shortcuts to achieving this.  The first thing you need to do is check Layer mask hides effect in the layer style panel
              You'll already be using this workflow I suspect, but it then boils down to:
              Adding a layer mask to each box object
              Ctrl clicking the relevant box layer to load it as a selection, inverting the selection, and filling each layer mask with black
              That will make the part outside the box disappear, so Ctrl click each object in turn, and fill its layer mask with white.
              You now have the box contents back, but the drop shadow overlap will be gone outside the box, so it is a matter of hand painting it back in the layer mask.
              If you were feeling very clever, you could arrive at the required selection using calculations, but that would make my head hurt.
              Here's a slightly better workflow. Before you add the layer mask, Ctrl click each box object in turn to load as a selection, and add the layer mask. That leaves you with no shadow.
              Then hand paint the shadows back in.  You can help yourself by Ctrl clicking other objects to restrain where the shadow is painted in.   That's the best I can think of right now, but what often happens here is that one idea prompts other users to think of another wrinkle, so fingers crossed.
              2 people found this helpful
              • 4. Re: Prevent drop shadow from showing on transparent pixels
                Kalow Level 1
                Looks like it's just going to be tedious.
                Thanks for the suggestions - love the bananas. I've tried variations of all these, and yes they work for most situations. I didn't know about the "Layer Mask Hides Effect" default setting though - so I learned something new!
                Of course, as soon as I transform an object the mask has to be redone. (see below) I think one mega-mask for the group might be the best option.
                The illustrations I usually deal with are much more complex than this (think Sam's/Costco size pallets filled with hundreds of items) So scrolling through groups and Shift+Ctrl clicking layers is a pain in the neck. Fortunately the effects do not have to be turned OFF in order to make the selection.
                Anyone know of a way to select visible pixels for more than one layer at a time, or toggle layer effects on/off for multiple layers?
                • 5. Re: Prevent drop shadow from showing on transparent pixels
                  Chuck Uebele Adobe Community Professional & MVP
                  To make life easier, I wrote a script for another thread that makes a selection of all layers in a group. You could use that to create a new mask. However, some code should be added to turn off the layer effects visibility.
                  forums.adobe.com/message/7753221#7753221
                  • 6. Re: Prevent drop shadow from showing on transparent pixels
                    Kalow Level 1
                    This is very cool. Unfortunately it doesn't seem to work with Smart Objects, only after I rasterize each layer.
                    No need to turn the shadow effect off though, It selects only the drawn pixels.
                    • 7. Re: Prevent drop shadow from showing on transparent pixels
                      Haven't tested it with SO, guess I'll have to take a look at that.
                      • 8. Re: Prevent drop shadow from showing on transparent pixels
                        Now it works with Smart Objects:
                        #target photoshop
                        var doc = activeDocument;
                        var gp = doc.activeLayer
                        var bound = false
                        var curLayer
                        getLayers (gp)
                        function getLayers(gp1){
                            for(var i=0;i<gp1.layers.length;i++){
                                try{
                                    var check = doc.selection.bounds
                                    bound =true;
                                catch(e){bound = false}
                                doc.activeLayer = curLayer = gp1.layers[i];
                                if(curLayer.typename =='LayerSet'){getLayers (gp1.layers[i])}
                                else{
                                        if(curLayer.kind == 'LayerKind.NORMAL' || curLayer.kind=='LayerKind.SMARTOBJECT'){
                                            if(bound){selPx ()}
                                            else{selPxFirst ()};
                                        else{
                                            try{
                                                if(bound){selShape ()}
                                                else{selShapeFirst ()};
                                            catch(e){}
                            doc.activeLayer = gp
                            }//end function
                        function selPxFirst(){
                            var idsetd = charIDToTypeID( "setd" );
                                var desc7 = new ActionDescriptor();
                                var idnull = charIDToTypeID( "null" );
                                    var ref7 = new ActionReference();
                                    var idChnl = charIDToTypeID( "Chnl" );
                                    var idfsel = charIDToTypeID( "fsel" );
                                    ref7.putProperty( idChnl, idfsel );
                                desc7.putReference( idnull, ref7 );
                                var idT = charIDToTypeID( "T   " );
                                    var ref8 = new ActionReference();
                                    var idTrsp = charIDToTypeID( "Trsp" );
                                    ref8.putEnumerated( idChnl, idChnl, idTrsp );
                                desc7.putReference( idT, ref8 );
                            executeAction( idsetd, desc7, DialogModes.NO );
                        function selPx(){
                            var idAdd = charIDToTypeID( "Add " );
                                var desc5 = new ActionDescriptor();
                                    var ref5 = new ActionReference();
                                    ref5.putEnumerated( idChnl, idChnl, idTrsp );
                                desc5.putReference( idnull, ref5 );
                                    var ref6 = new ActionReference();
                                    ref6.putProperty( idChnl, idfsel );
                                desc5.putReference( idT, ref6 );
                            executeAction( idAdd, desc5, DialogModes.NO );
                        function selShapeFirst(){
                                var desc2 = new ActionDescriptor();
                                    var ref1 = new ActionReference();
                                    ref1.putProperty( idChnl, idfsel );
                                desc2.putReference( idnull, ref1 );
                                    var ref2 = new ActionReference();
                                    var idPath = charIDToTypeID( "Path" );
                                    var idvectorMask = stringIDToTypeID( "vectorMask" );
                                    ref2.putEnumerated( idPath, idPath, idvectorMask );
                                    var idLyr = charIDToTypeID( "Lyr " );
                                    var idOrdn = charIDToTypeID( "Ordn" );
                                    var idTrgt = charIDToTypeID( "Trgt" );
                                    ref2.putEnumerated( idLyr, idOrdn, idTrgt );
                                desc2.putReference( idT, ref2 );
                                var idVrsn = charIDToTypeID( "Vrsn" );
                                desc2.putInteger( idVrsn, 1 );
                                var idvectorMaskParams = stringIDToTypeID( "vectorMaskParams" );
                                desc2.putBoolean( idvectorMaskParams, true );
                            executeAction( idsetd, desc2, DialogModes.NO );
                        function selShape(){
                            var idAddT = charIDToTypeID( "AddT" );
                                var desc13 = new ActionDescriptor();
                                    var ref14 = new ActionReference();
                                    ref14.putProperty( idChnl, idfsel );
                                desc13.putReference( idnull, ref14 );
                                    var ref15 = new ActionReference();
                                    ref15.putEnumerated( idPath, idPath, idvectorMask );
                                    ref15.putEnumerated( idLyr, idOrdn, idTrgt );
                                desc13.putReference( idT, ref15 );
                                desc13.putInteger( idVrsn, 1 );
                                desc13.putBoolean( idvectorMaskParams, true );
                            executeAction( idAddT, desc13, DialogModes.NO );
                        • 9. Re: Prevent drop shadow from showing on transparent pixels
                          Kalow Level 1
                          Amazing!! This is far beyond my understanding, but it works like a charm. Thank you, Chuck!
                          (And if anyone from Adobe is listening - I'd still like a "shadow ignores transparent pixels) option.)
