Hello everyone! How can I fill a transparent spot with the patch tool? I tried a few things but my transparent spot stays...transparent.
[Moderator: moved from Lounge to Photoshop]
If there is nothing there at all, you will have better luck with the Clone Stamp tool to replace the transparent pixels.
Which product and version are you using, please?
This is the forum Lounge. We don't field product related questions here. But a moderator can move this to the correct product forum for you.
Oh! I'm sorry. I just started using Adobe products. It's Photoshop CC 2017 related. Thank you.
Ok thanks! I'll try it with the clone stamp tool.
created by jane-e <https://forums.adobe.com/people/jane-e> in *Photoshop
General Discussion* - View the full discussion
<https://forums.adobe.com/message/9389699#9389699>
It worked pretty well. Thank you!
Great! To confirm, was it the Clone Stamp tool or the Brush tool with the blend mode of behind?
Actually, both methods worked. Clone Stamp tool brings more details to the empty parts and the Brush tool fills easily and is faster to use. Thank you !
It worked. Thank you!
You can paint the transparent area with your brush blend mode set to 'Behind'. Select the brush and look for the blend mode in the options bar at the top. By default it will say 'Normal".
