16 Replies Latest reply on Feb 26, 2018 6:42 AM by christophk31943473
    Mass export all images as individual JPEGs?
    rachellefacistolmata Level 1
      Hi! I am new to Indesign. I have a file that contains images with Photoshop clipping paths. I want to export all the clipped images in a folder. I have tried doing the "Copy Links To" and it successfully exported the original images. However, I do not want the original images but the clipped images instead. Is there a way for me to export all the clipped images as JPEG or TIFF and not the original linked image? In short, I want to export the images without their background. I hope I'm making sense. I have about 800-1000 images so a batch processing method would be highly appreciated.
      I actually found a way to export the images the way I want them to be. I just need to click the image container (not the image), go to File>Export and then export it as JPEG. In the pop up window, I choose export selection, maximum quality, and 2400 resolution. It exports the images the way I want them to be. But I have to do this one by one. I just have two concerns:
      1. Is there a way for me to do this by batch? Like select all the image containers and export them one by one automatically?
      2. Is there a way to automatically name the saved files according to the original image name?
      Thank you for your help!
        • 1. Re: Mass export all images as individual JPEGs?
          I found this script in another forum and modified it a bit to suit my needs. It appears to work in most of my INDD documents, but it fails in others. I wonder why. I get the error message that
          Error string: null is not an object
          Source: fileName = File ( rect.graphics[0].itemLink.filePath ).name;
          I also noticed that it skips some objects and doesn't download all of the images.
          test();
          function test()
          var myDoc = app.activeDocument,
          apis = myDoc.allPageItems, rect, fileName;
          while ( rect = apis.pop() )
              if ( !(rect instanceof Rectangle) || !rect.graphics[0].isValid ){ continue; }
              fileName = fileName.replace( /\.[a-z]{2,4}$/i, '.jpg' );
              app.jpegExportPreferences.exportResolution = 2400;
              app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.MAXIMUM;
              //give it a unique name
              var myFile = new File ("C:/Users/RANFacistol-Mata/Desktop/Image Trial/"+ fileName);
              rect.exportFile(ExportFormat.JPG, myFile);
          Is there a way for me to modify this script such that instead of iterating through all the rectangles, I would iterate through all the objects instead, much like clicking this icon.Next.PNG
          And then check if that object contains an image. If it does, then I will export it as scripted above.
          Thanks!
          • 2. Re: Mass export all images as individual JPEGs?
            Jump_Over Level 5
            I suggest to iterate through links instead of objects ==> so no link means no action
            starting part of code:
            var
                apis = myDoc.links.everyItem().getElements(),
                rect, fileName;
                rect = rect.parent.parent;
                if ( !(rect.hasOwnProperty ("graphics") ){ continue; }
            Jarek
            • 3. Re: Mass export all images as individual JPEGs?
              Hello Jarek,
              Thank you for this suggestion. You're right. It's actually more efficient to iterate through the links than through the objects. However, I have one more concern. Not all of my linked images are in a rectangle. Some of them are in polygons, and some are in arbitrary shapes (like the edges have been followed). Can you suggest a way for me to catch those instances too?
              Thanks!
              • 4. Re: Mass export all images as individual JPEGs?
                Hi Jarek,
                Your solution works like a charm.
                Thank you!
                • 5. Re: Mass export all images as individual JPEGs?
                  Jump_Over Level 5
                  var rec covers all 'graphic' shapes. (link.parent.parent)
                  Its name is just left to reduce modifications
                  Jarek
                  • 6. Re: Mass export all images as individual JPEGs?
                    Trevorׅ Adobe Community Professional
                    Hi Rachelle
                    I think Jarek has answered your question so please mark his answer as correct
                    Trevor
                    • 7. Re: Mass export all images as individual JPEGs?
                      schroef Level 1
                      Is there a method for rachellefacistolmata script to export the image but take the orginal linked image into account. Now it exports a JPG using the frames ratio.
                      Not sure if this is clear, ive added some screengrabs to make it more clear
                      Placed image
                      exported image
                      Original linked image
                      My guess its due to the "
                      if (!(rect.hasOwnProperty("graphics"))) {
                      • 8. Re: Mass export all images as individual JPEGs?
                        Jump_Over Level 5
                        In other words - is your goal to rename/change directory of original file instead of export?
                        if so there is a method:
                        oldFile.copy(newFile);
                        Jarek
                        • 9. Re: Mass export all images as individual JPEGs?
                          schroef Level 1
                          @Jarek,
                          Not sure if you directed it at me. But i asked this question on StacjExchange as well and good help there. The script now exports the image and not images in form of the rectangle. I didnt even know that wa possible, exporting the shape from indesign?
                          Anyways here's the script if other would perhaps need it or change it. Better take out those alerts, perhaps the done can stay but the other is sort of useless
                            items, fileName;
                          var i = 0;
                          var MyPath = "C:/Users/xx/Desktop/test/"; // change your path here
                          alert("Script is running. Press OK and wait until done...");
                          while (items = apis.pop()) {
                            items = items.parent.parent;
                             if (!(items.hasOwnProperty("graphics"))) {
                             continue;
                            i++;
                             try {
                            fileName = File(items.graphics[0].itemLink.filePath).name;
                            fileName = i + "_" + fileName.replace(/\.[a-z]{2,4}$/i, '.jpg');
                             } catch (e) {};
                             var myFile = new File(MyPath + fileName);
                            items.graphics[0].exportFile(ExportFormat.JPG, myFile);
                          alert("Done");
                          • 10. Re: Mass export all images as individual JPEGs?
                            christophk31943473 Level 1
                            Hi there, thanks for the script - have been looking for something like that for some time.
                            • In what order are the images exported? is it possible to change the order?
                            • Is it possible to add the page-number to the name of the exported .jpeg?
                            Christoph
                            • 11. Re: Mass export all images as individual JPEGs?
                              Hi Christoph,
                              from the code given in reply #9 the order is in the order of the links with array named apis.
                              What order do you prefer?
                              It's also possible to add a page name or the absolute number of a page in a document to the exported images.
                              To get the page object you could ask for link.parent.parent.parentPage. Note: if the object is on the pasteboard this will return null.
                              And if you have a valid page object then go for:
                              page.name
                              or:
                              ( page.documentOffset + 1).toString()
                              See Jongware's DOM documentation:
                              Indesign JavaScript Help
                              Adobe InDesign CS6 (8.0) Object Model JS: Page
                              Or Gregor Fellenz' DOM documentation:
                              https://www.indesignjs.de/extendscriptAPI/indesign-latest/#Page.html
                              Regards,
                              Uwe
                              • 12. Re: Mass export all images as individual JPEGs?
                                thanks for your reply - as i am totally unexperienced in java or any other language, i have to ask for more details.
                                the code from reply 9 states the file name as:
                                1.   fileName = i + "_" + fileName.replace(/\.[a-z]{2,4}$/i, '.jpg');
                                so from what i understand, i have to add something here. Like:
                                1.   fileName = i + "_" + link.parent.parent.parentPage +fileName.replace(/\.[a-z]{2,4}$/i, '.jpg');
                                but that is not working for me.
                                When i execute the script - the files are not renamed - but saved with their old filename
                                Concerning the order - i would like to order it by pagenumber and from top left to the right bottom.
                                Thanks!!
                                Christoph
                                • 13. Re: Mass export all images as individual JPEGs?
                                  Hi Christoph,
                                  link.parent.parent.parentPage.name
                                  The value of property name of a page is the string you are looking for.
                                  Regards,
                                  Uwe
                                  • 14. Re: Mass export all images as individual JPEGs?
                                    Hi Uwe,
                                    sorry - but it is not working - i am using indesign cc on a mac, by the way.
                                    Without  the link.parent.parent.parentPage.name the images are renamed correctly.
                                    Could you check the code?
                                    Christoph
                                      items, fileName;
                                    var i = 0;
                                    var MyPath = "/Users/cko/Desktop/asd/"; // change your path here
                                       continue;
                                      i++;
                                       try {
                                      fileName = i + "_" + link.parent.parent.parentPage.name + fileName.replace(/\.[a-z]{2,4}$/i, '.jpg');
                                       } catch (e) {};
                                    alert("Done");
                                    • 15. Re: Mass export all images as individual JPEGs?
                                      Hi Christoph,
                                      it's not working because my link in the code is referring to an actual link in the document.
                                      You have to translate that to the actual code you are working with.
                                      The array of links in your code is apis.
                                      The current link the while loop is working on is items.
                                      But items is redefined with items.parent.parent which is the container of the image.
                                      So in the end you'll need:
                                      items.parentPage.name
                                      to define the name of the page.
                                      Regards,
                                      Uwe
                                      • 16. Re: Mass export all images as individual JPEGs?
                                        Hi Uwe,
                                        thanks! Now it works..
                                        You saved my weekend!!
                                        Kind Regards
                                        Christoph
