1. Re: Help! Brush thickness stays same
davescm Mar 14, 2017 12:35 PM (in response to lanm25716822)1 person found this helpfulAre you controlling this with a tablet and pen? If so there appears to be an issue with Photoshop seeing your pen pressure (hence the warning triangle in your last screenshot).
Can you give some details of your system, Photoshop version and (if applicable) tablet make/model
Dave
2. Re: Help! Brush thickness stays same
josephlavine Mar 14, 2017 12:44 PM (in response to lanm25716822)1 person found this helpfulI'm guessing (and could be wrong) that you are using a mouse and not a tablet w/pressure sensitivity. The change in brush shape/contour is created by pressure, which cannot be with a mouse. Please let me know if I am mistaken.
3. Re: Help! Brush thickness stays same
lanm25716822 Mar 14, 2017 1:13 PM (in response to davescm)First, I'm so grateful that you replied my post.
Then answering your questions:
1, I just used the Mac mouse to draw the lines.
I already tried to reset the Photoshop Preference , but it didn't work. And I tried to reset different factors in the Brush Panel to observe whether it's improved, like clicking the "pen pressure"(the last screenshot you just saw). But the result is the same. Other control choices are also tried.
2, my Photoshop version is Photoshop CC 2015.
4. Re: Help! Brush thickness stays same
lanm25716822 Mar 14, 2017 1:26 PM (in response to josephlavine)Oh, I see. So even if it is the Photoshop default brush, we have to use the pen to draw lines.
But I'm still a little confused. I loaded the Kyle's brushes and he said we don't need to use the Pen with his brush preset. Finally thank you very much.
5. Re: Help! Brush thickness stays same
josephlavine Mar 14, 2017 1:41 PM (in response to lanm25716822) -
6. Re: Help! Brush thickness stays same
lanm25716822 Mar 14, 2017 2:01 PM (in response to josephlavine)Thank you very much. I'm going to buy the tablet pen.
7. Re: Help! Brush thickness stays same
lanm25716822 Mar 14, 2017 2:02 PM (in response to davescm)Thanks again for your friendly reply just now.
8. Re: Help! Brush thickness stays same
davescm Mar 14, 2017 2:16 PM (in response to lanm25716822)........ I'm going to buy the tablet pen.
If you do much drawing/painting you will find it well worth it
Dave
