6 Replies Latest reply on Jan 6, 2009 7:05 AM by Newsgroup_User
    Multiple Paragraph Styles
    Jens Peermann Level 2
      Is it possible to have multiple paragraph styles in one document? With tags like p1, p2, p3... similar to h1, h2, h3...
        • 1. Re: Multiple Paragraph Styles
          Level 7
          Yes, but there is only the <p> tag to work with. In this case you'd need to
          use CSS to find the desired paragraph and apply the desired style to it.
          For example, you might have -
          <style type="text/css">
          .LeadPara { color:red; }
          .InteriorPara { color:blue; }
          .TailPara { color:green; }
          </style>
          </head>
          <body>
          <p class="LeadPara">blah blah</p>
          <p class="InteriorPara">blah blah</p>
          <p class="TailPara">blah blah</p>
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "Jens Peermann" <webforumsuser@macromedia.com> wrote in message
          news:gjtsqo$k4p$1@forums.macromedia.com...
          • 2. Re: Multiple Paragraph Styles
            Thanks, Murray.
            Unfortunately, the Styles don't override the margin and padding settings I have in the <p> tag. Probably because I have rather large settings in there and the Styles have smaller ones. It might work the way around - small setting in <p> and large ones in the Styles - but that wold require re-coding a bunch of templates, changing the workflow for a few people and re-training those people.
            I think I'll just hijack the <h5> and <h6> tags. I don't use them for anything else.
            • 3. Re: Multiple Paragraph Styles
              Level 7
              > anything
              > else.
              Do that at the risk of affecting your search engine ranking. Those tags
              have semantic meaning which is considered by the SE's.
              Why do you have margin and padding in the <p> tags? Why not move it all to
              a stylesheet?
              news:gju0hb$oub$1@forums.macromedia.com...
              > Thanks, Murray.
              > there and
              > in
              > of
              > people.
              > anything
              > else.
              • 4. Re: Multiple Paragraph Styles
                Level 7
                On Mon, 5 Jan 2009 22:10:51 +0000 (UTC), "Jens Peermann"
                They should if you've done it correctly.
                Gary
                • 5. Multiple Paragraph Styles
                  quote:
                  Gary
                  Is there more than just entering the values into the fields in the dialog box?
                  • 6. Re: Multiple Paragraph Styles
                    Level 7
                    On Tue, 6 Jan 2009 05:39:33 +0000 (UTC), "Jens Peermann"
                    We'd have to see the code that it generated to tell if there is something
                    interfering with it.
                    Gary
