2 Replies Latest reply on Mar 16, 2017 11:46 AM by juliel96058674
    Palette window buttons are unresponsive when launched using BridgeTalk
    juliel96058674 Level 1
      I have come across several instances in Windows Photoshop CC 2015 when the palette buttons are unresponsive. The purpose of the palette in this case is to stall the application until a bat script completes while still giving the user the option to "cancel" if necessary.
      I haven't had any success creating the palette window with and without BridgeTalk(). It almost seems like there is a ScriptUI parenting issue since the entire panel appears to be disabled. Please let me know if anyone has come across this issue or if there's a known workaround. Thanks!
      Here's an example:
      Ex)
      function WinObject() {
           var windowResource = "palette { orientation: 'column', alignChildren: ['fill', 'top'], preferredSize:[300, 130], text: 'ScriptUI Window - palette', margins:15,            bottomGroup: Group{cancelButton: Button { text: 'Cancel', properties:{name:'cancel'}, size: [120,24]}}    }";
           var win = new Window(windowResource);
           win.bottomGroup.cancelButton.onClick = function() {
                scriptRunning = false;
                win.close()
           var scriptRunning = true;
           win.show();
           while (scriptRunning)
                app.refresh();
           win.close();
      var message = WinObject.toString() + "\nnew WinObject();";
      var bt = new BridgeTalk();
      bt.target = "photoshop";
      bt.body = message;
      bt.onResult = function(obj)
             alert("RECEIVE ON RESULT");
      bt.send(5);
        • 1. Re: Palette window buttons are unresponsive when launched using BridgeTalk
          You usually only need to wait for a Bat file to complete when you need to use what the bat file or executable creates. What I do is  set some up to something I can test for in the script the indicates that process has completed.  I loop the script looking for the signal  Then put out an alert Thes process did not complete yet. This Alert paused the script. When the user dismisses the alert I test again. It the signal has happened during the alert I continue else I abort.
          StartPgm(path,program,options,pbmName);                                           // Create eps file
            app.refresh();        // slow down Photoshop with a refresh
            for (var i=0;i<100000;i++) { if (!testeps.exists) break; }                          // wait a short time before forcing a pause
            if (!testeps.exists) {alert('File "' + testeps + '" was not cteated yet'); }    // force a pause
            if (!testeps.exists) {alert('File "' + testeps + '" was not cteated'); return;}
          • 2. Re: Palette window buttons are unresponsive when launched using BridgeTalk
            yes, I suppose that's a valid workaround. I was really hoping to get this to work with the palette in order to give the user more control.
